Home > Maintenance & Modifications > Suspension Midule
TommyM
United Kingdom 2007 Range Rover Sport TDV8 HSE Zambezi Silver
Suspension Midule
Can someone tell me where suspension control module is found on 2007 rrs 3.6 tdv8 hse please
Post #627910 Thu Nov 03 2022 5:34pm
karlos01
The air suspension control module on the Land Rover Discovery 3 is located behind the driver's side instrument panel.
Post #627911 Thu Nov 03 2022 5:51pm
TommyM
Is the range rover sport the same Karlos
Post #627929 Fri Nov 04 2022 7:21am
karlos01
range rover sport is a Discovery 3 on steroids lol
Post #627931 Fri Nov 04 2022 10:11am
karlos01
Post #627932 Fri Nov 04 2022 10:13am
TommyM
Thanxs m8 I only know its l320, didn't know it was same chassis etc
Post #627935 Fri Nov 04 2022 10:57am
The air suspension module is up on the base of the A-pillar behind the dashboard. You can access it by dropping the panel below the steering wheel and then reach up above the pedals. It's a bit tight but you can get to it. 2012 SDV6 - it's missing a couple of cylinders
Post #627936 Fri Nov 04 2022 10:58am
TommyM
Thank you, will get round to it soon as height sensors changed, having to wait for parts, even from main dealers here in Belfast
Post #627939 Fri Nov 04 2022 11:34am
Are you thinking of changing the module? Why? If you do, you need to set it up as it contains different settings for the heavier TDV8 to the other versions. 2012 SDV6 - it's missing a couple of cylinders
Post #627941 Fri Nov 04 2022 11:52am
TommyM
Am changing height sensors but another forum suggested it could be module, I know I would have to get it recoded if it does need changing
Post #627958 Fri Nov 04 2022 4:50pm
karlos01
whats up with it?
Post #627961 Fri Nov 04 2022 7:46pm
TommyM
Sometimes front os or ns goes into extended mode for no apparent reason, have noticed only when really wet here, so think height sensor sticking or possibly sticky valve block am working through things
Post #627962 Sat Nov 05 2022 7:51am
rayodunne
Canada 2009 Range Rover Sport Supercharged Santorini Black
Your air suspension system is full of the desiccant from the compressor dryer. The compressor exhaust valve is sticking due to this contamination. When the vehicle tries to lower the air can't leave the system and the system goes to extended due to thinking its hung-up on something. 2009 Range Rover Sport Supercharged
Post #628005 Mon Nov 07 2022 2:03pm
TommyM
Do I need to replace anything, or can good mechanic clean it, have problem with hands so would not be able to do it, would this cause amber suspension light with normal height only or is that another issue m8
Post #628139 Fri Nov 11 2022 2:06pm
