Home > Maintenance & Modifications > Suspension Midule |
TommyM Member Since: 02 Nov 2022 Location: Belfast Posts: 19 |
Can someone tell me where suspension control module is found on 2007 rrs 3.6 tdv8 hse please |
Thu Nov 03 2022 5:34pm |
Is the range rover sport the same Karlos |
Fri Nov 04 2022 7:21am |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
range rover sport is a Discovery 3 on steroids lol |
Fri Nov 04 2022 10:11am |
Fri Nov 04 2022 10:13am |
Thanxs m8 I only know its l320, didn't know it was same chassis etc |
Fri Nov 04 2022 10:57am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
The air suspension module is up on the base of the A-pillar behind the dashboard. You can access it by dropping the panel below the steering wheel and then reach up above the pedals. It's a bit tight but you can get to it. 2012 SDV6 - it's missing a couple of cylinders
Fri Nov 04 2022 10:58am |
Thank you, will get round to it soon as height sensors changed, having to wait for parts, even from main dealers here in Belfast |
Fri Nov 04 2022 11:34am |
Are you thinking of changing the module? Why? If you do, you need to set it up as it contains different settings for the heavier TDV8 to the other versions. 2012 SDV6 - it's missing a couple of cylinders
Fri Nov 04 2022 11:52am |
Am changing height sensors but another forum suggested it could be module, I know I would have to get it recoded if it does need changing |
Fri Nov 04 2022 4:50pm |
whats up with it? |
Fri Nov 04 2022 7:46pm |
Sometimes front os or ns goes into extended mode for no apparent reason, have noticed only when really wet here, so think height sensor sticking or possibly sticky valve block am working through things |
Sat Nov 05 2022 7:51am |
rayodunne Member Since: 17 May 2018 Location: Sudbury Posts: 37 |
Your air suspension system is full of the desiccant from the compressor dryer. The compressor exhaust valve is sticking due to this contamination. When the vehicle tries to lower the air can't leave the system and the system goes to extended due to thinking its hung-up on something. 2009 Range Rover Sport Supercharged |
Mon Nov 07 2022 2:03pm |
Do I need to replace anything, or can good mechanic clean it, have problem with hands so would not be able to do it, would this cause amber suspension light with normal height only or is that another issue m8 |
Fri Nov 11 2022 2:06pm |
