Home > General > My new to me 2006 supercharged fixes and faults.
Page 4 of 9 <123456789>
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Cleaned the other side and finished the bonnet
Will start on the wheels soon, have rubbed down the bad paint on the roof will get it etched primed and sanded for top coat sooner rather than later
Post #626180 Fri Aug 19 2022 6:28pm
skid1963
Thumbs Up 2015 L494 SDV6 3.0 HSE Dynamic
2006 L320 4.2 Supercharged
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #626182 Fri Aug 19 2022 6:40pm
Lrstaylor
Found an hour to etch prime the peeling roof paint it will do over the winter if iv still got the sc next spring it will go in for bady work. Still got the sc snout to overhaul just don't seem to get any free time.
Did manage to swop out the front grill for the correct type.
Old grill hst spec I believe
Correct sc grill waiting on a new badge
Post #626573 Sat Sep 10 2022 8:27pm
Lrstaylor
Wheels replaced, big thanks to Richard on here who I bought the wheels from he delivered then as well while down my way for work. This now gives me time to refurb the originals at some point. Still have the sc to service and lower control arm to replace.
Paint and body work next spring me thinks
Post #627245 Mon Oct 10 2022 9:51am
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Hi there! what did you use on the external C pillar trim?
Post #627246 Mon Oct 10 2022 10:44am
Lrstaylor
Electric polisher with an orange pad with a few blobs of macquires scratch remover. Came up like new.
Post #627252 Mon Oct 10 2022 6:32pm
Lrstaylor
Took advantage of the last of the nice weather and swopped out the suspension pump, it was working but would put up "raising slowly" when raising due to the piston being worn from the previous owner who ran around with a permanent suspension fault due to the usual crack in the air drier back plate which I fixed the 1st week I got the car.
The removed pump is a genuin landrover so a result iv got a new piston and barrel waiting to go on plus air drier medium.
A fully strip down and rebuild next week then I like to keep a spare working pump on the shelf in the garage. And iv just used the new 1 well...........I'm a pump short.
O/S lower control are and both track rod ends to do then finally the s/c snout refurb iv been promising my self
Post #627770 Sat Oct 29 2022 4:55pm
Lrstaylor
Got around to swopping out all the interior bulbs for led including the vanity mirrors and wing mirror puddle lights.
It's the little things.....
Post #627966 Sat Nov 05 2022 3:40pm
Lrstaylor
Mot day today, clean bill of health.
RESULT
Post #628311 Thu Nov 17 2022 9:04pm
Lrstaylor
Heated windscreen
1st proper frost of the year so used the heated screen function for the 1st time only to find the passenger side didn't defrost doh. Drivers side cleared in a couple of minutes.
So break out the multi metre first things to check are the under bonnet fuses 30 amp x2 one for each side. Yep all good relay works easy check is to remove and refit it you should hear and feel it click.
Next is to pull off the internal A pillar covers the are x2 connection on each side for the screen heater elements top one has purple wire that's the power in quick check with the dvm yep 14ish volts. Engine running heated screen function selected.
Next the bottom connector it's got a black wire that's the ground you don't get any volt reading here you need to test for ground at the connector, make sure all the cars power is off no ignition on. Turn the dvm to continuity you can use the the heads of the bolts on the inside of the A pillar for a ground connection for 1 lead of the dvm the other lead to the black connector......zero ohms is what your after.
Well all those checks seem to suggest the cars electrics are working fine the final check is to unplug the screen element connectors from the x2 plugs and test the screen for continuity these are the ribbon like connector.
You should get 1 ohm resistance........ Censored iv got 53.2 ohms that's way to high conclusion is the heated screen element on the passenger side is open circuit.
The only fix for this is a new screen as its a function that's hardly used I think this will be left.
Double trouble the new to us V8 D3 ulez cars heated screen also failed to operate same tests performed fault found to be poor connection at the earth side of the screen both left and right. Quick clean up and all fixed.
Result.....partly.
Post #628962 Thu Dec 08 2022 8:53pm
Lrstaylor
New thermostat fitted the old one was jammed open causing over cooling seems to be a common issue with this type of 3 piece stat. Engine and car warm up nicely now.
Post #628977 Fri Dec 09 2022 3:05pm
So what year d3 v8 is ulez complient
Post #628987 Sat Dec 10 2022 5:25am
Lrstaylor
Any year there all good for the ulez.
Post #628988 Sat Dec 10 2022 8:49am
Lrstaylor
P01710 p01740
Cars been throwing lean codes bank 1 since I replaced the stat and reset the fuel trims with my gap tool. Just to be safe got out the smoke machine and checked for any vacuum leaks.......none found. Then it started throwing lean codes for both banks well I had a new maf sitting here I dropped it in cleared the fuel trims again and it's been good all day where as before the engine light would come on within 15 mins of driving.
Fingers crossed.
Hopefully will find time to replace the sc bearings and coupler over xmas
Post #629307 Tue Dec 20 2022 4:10pm
Lrstaylor
Was time to sort the sc bearing and coupler today started about 1030 x2coffe breaks and it's off
Time to strip the sc down and replace the bearings and coupler, bacon bap and coffe 1st.
Post #631154 Sat Feb 25 2023 12:03pm
