Home > General > My new to me 2006 supercharged fixes and faults. |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 210 |
2015 L494 SDV6 3.0 HSE Loire Blue
Fri Aug 19 2022 6:40pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 |
Found an hour to etch prime the peeling roof paint it will do over the winter if iv still got the sc next spring it will go in for bady work. Still got the sc snout to overhaul just don't seem to get any free time.
Sat Sep 10 2022 8:27pm |
Wheels replaced, big thanks to Richard on here who I bought the wheels from he delivered then as well while down my way for work. This now gives me time to refurb the originals at some point. Still have the sc to service and lower control arm to replace.
Mon Oct 10 2022 9:51am |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 |
Hi there! what did you use on the external C pillar trim? |
Mon Oct 10 2022 10:44am |
Electric polisher with an orange pad with a few blobs of macquires scratch remover. Came up like new. |
Mon Oct 10 2022 6:32pm |
Took advantage of the last of the nice weather and swopped out the suspension pump, it was working but would put up "raising slowly" when raising due to the piston being worn from the previous owner who ran around with a permanent suspension fault due to the usual crack in the air drier back plate which I fixed the 1st week I got the car.
Sat Oct 29 2022 4:55pm |
Got around to swopping out all the interior bulbs for led including the vanity mirrors and wing mirror puddle lights.
Sat Nov 05 2022 3:40pm |
Mot day today, clean bill of health.
Thu Nov 17 2022 9:04pm |
1st proper frost of the year so used the heated screen function for the 1st time only to find the passenger side didn't defrost doh. Drivers side cleared in a couple of minutes.
Thu Dec 08 2022 8:53pm |
New thermostat fitted the old one was jammed open causing over cooling seems to be a common issue with this type of 3 piece stat. Engine and car warm up nicely now. |
Fri Dec 09 2022 3:05pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4975 |
So what year d3 v8 is ulez complient |
Sat Dec 10 2022 5:25am |
Any year there all good for the ulez. |
Sat Dec 10 2022 8:49am |
Cars been throwing lean codes bank 1 since I replaced the stat and reset the fuel trims with my gap tool. Just to be safe got out the smoke machine and checked for any vacuum leaks.......none found. Then it started throwing lean codes for both banks well I had a new maf sitting here I dropped it in cleared the fuel trims again and it's been good all day where as before the engine light would come on within 15 mins of driving.
Tue Dec 20 2022 4:10pm |
Sat Feb 25 2023 12:03pm |
