Home > General > Air suspension compressor required |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 247 |
A bit of research shows that the new LR compressor is the one to go for. |
Sat Aug 20 2022 10:45am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
The Hitachi is the genuine Land Rover item - is easy to rebuild rather than getting a new one.
Sat Aug 20 2022 11:01am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
If the Vin No. is prior to BA708255 it could well be a Hitachi, as according to L/R they did not start fitting the AMK till after that vin. number. On some MY12/13 cars they reverted back to the Hitachi and then back to the AMK again, just to confuse things. Drop the plastic cover and have a look, easy enough to tell the difference.
Sat Aug 20 2022 11:23am |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Sounds a bit like they just had a rummage in the parts bin at the factory to see what compressors they could find, Col! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Mon Aug 22 2022 10:37am |
Update: I’ve had the new AMK compressor fitted (software update included) and also had the air tank replaced. The tank was particularly corroded by the pipe fittings.
Fri Oct 14 2022 8:50am |
