![]() | Home > General > My new to me 2006 supercharged fixes and faults. |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Gave it a lite coat of etch primer to highlite where I need to rub down with my wet n dry.
Replaced the troublesome pcv pipe with a new home made rubber effort x2 22mm to 19mm reducer 45 degree elbows. You have to remove the throttle body todo this and I'm glad I did the gasket on the throttle body was wet it looks like it's been sucking in oil from the pcv pipe connection on the back of the housing.
Got a couple of jobs done, painted the spare wheel to see if I like the colour.
Managed to find and fix another fault....the supercharged coolant pump packed up as per my other post regarding this issue iv rewired it the correct way round as its been running backwards since 2006 gave it a whack with the end of my screw driver and its working a good un. New pump on order just incase the brushes don't re profile nicely.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 ![]() ![]() ![]() |
You could always remove your SC belt for a few days and see |
Now that's a good idea |
Decided to swop out my failing supercharged aux cooling pump it was wired back to front from factory but dispite my rewiring it correctly and the pump running after a whack with the end of a screw driver it just didn't recover.
New tyres fitted last week, wheel alignment done today. Last couple of jobs left on the list.
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 ![]() ![]() ![]() |
love the wheel color! I've got a Rimini red 2005 with wheels colored to match the Titanium trim. Just grabbed some spares recently and had 2 refurbed. Will swap tires and refurb another 2 etc.
I'm a big fan of the rimini red |
Time to address the paint with a bit of light correction, it needs paint on the roof some of its missing, that's another day and I'm replacing the rear bumper at some point.
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 208 ![]() ![]() ![]() |
Looking good mate |
Cheers Mark, iv got plenty todo before it's finished and at the standard I want. To think this is gonna be the wife's ulez replacment for her D3 when the zone expands.
