Home > General > My new to me 2006 supercharged fixes and faults.
Page 3 of 9 <123456789>
skid1963
Got 4 of these if you're interested, totally unmarked, very good tyres
 2015 L494 SDV6 3.0 HSE Loire Blue
2006 L320 4.2 Supercharged
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #624339 Wed May 18 2022 11:05pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Spent a little bit of time on the wheel refurb as the plan is to fully refurb the ebay special to see if I like the new colour iv picked out. Curb rash all gone needs another wet n dry by hand then it's ready for etch primer.
Some before photos
Some after
Post #624354 Thu May 19 2022 7:00pm
Lrstaylor
Gave it a lite coat of etch primer to highlite where I need to rub down with my wet n dry.
Post #624356 Thu May 19 2022 8:16pm
Lrstaylor
Replaced the troublesome pcv pipe with a new home made rubber effort x2 22mm to 19mm reducer 45 degree elbows. You have to remove the throttle body todo this and I'm glad I did the gasket on the throttle body was wet it looks like it's been sucking in oil from the pcv pipe connection on the back of the housing.
No pictures I'm afraid.
Post #624431 Sun May 22 2022 12:01pm
Lrstaylor
Got a couple of jobs done, painted the spare wheel to see if I like the colour.
Tinted the windows rear of the B pillar
Not purfect but it will do for now.
Post #624618 Thu Jun 02 2022 7:41pm
Lrstaylor
This week's fault and I didn't know until it happend
Managed to find and fix another fault....the supercharged coolant pump packed up as per my other post regarding this issue iv rewired it the correct way round as its been running backwards since 2006 gave it a whack with the end of my screw driver and its working a good un. New pump on order just incase the brushes don't re profile nicely.
Iv also put on hold chasing the random cold start misfires as there is little to no logic to them as can be seen by the misfire counts. After a brain storming session they could be triggerd by the snout bearing being totally fecked and the knock sensors reading this as random misfires.......you can here the snout bearing on idle and feel it threw the engine and even if you place your hand on the airbox you can feel the rumble......time to pull the sc.
Final coat of paint went on the wheel and I think I like it I'm unsure if I want to clear coat it.
Post #624881 Sun Jun 19 2022 9:39pm
You could always remove your SC belt for a few days and see
Post #624885 Mon Jun 20 2022 8:10am
Lrstaylor
Now that's a good idea
Post #624887 Mon Jun 20 2022 8:44am
Lrstaylor
Aux coolant pump replacment
Decided to swop out my failing supercharged aux cooling pump it was wired back to front from factory but dispite my rewiring it correctly and the pump running after a whack with the end of a screw driver it just didn't recover.
I read a few old how to guides but they all seemed a bit erm crap...wish I had taken some photos.
I can confirm removing the headlight is pointless, to swop out the coolant pump was pretty easy in the end.
Remove fan couling
Unplug the electrical connector from the bottom of the pump access is via the black plastic cover removed by x4 push fit rivets.
Remove x1 left hand side aux clamp bolt as you look down at it 8mm don't even try to undo the right hand side clamp bolt. The only thing holding it in place are the x2 hoses, unclip these but NOT at the pump end. X1 hose at the top T piece and x1 at the rad end.
Then it's just a case of pulling the pump up and out from the tiny little space it lives in, you will need to wiggle it a bit and feed the long hose threw but it will come out.
Now you have your old aux pump with hoses attached on the deck swop them over to your new pump and refit in reverse, top up and bleed. You won't lose much coolant either so don't worry.
Total job time maybe 35 mins.
Post #625590 Thu Jul 21 2022 9:39pm
Lrstaylor
New tyres fitted last week, wheel alignment done today. Last couple of jobs left on the list.
SC snout bearings and maybe a smaller pulley
Bit of paint on the body to sort.
Wheel referb to finish.
Then I think its finished and ready to use.
Post #625904 Thu Aug 04 2022 1:59pm
frostmotorsport
New Zealand 2006 Range Rover Sport Supercharged Rimini Red
love the wheel color! I've got a Rimini red 2005 with wheels colored to match the Titanium trim. Just grabbed some spares recently and had 2 refurbed. Will swap tires and refurb another 2 etc.
Good choice of color if you ask me. Silver is boring
 Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Post #625954 Sat Aug 06 2022 6:14am
Lrstaylor
I'm a big fan of the rimini red
Post #625974 Sat Aug 06 2022 5:12pm
Lrstaylor
Time to address the paint with a bit of light correction, it needs paint on the roof some of its missing, that's another day and I'm replacing the rear bumper at some point.
This is the state of external C pillar
After a bit of correction but offside one
Scratches around the handles pretty much gone now
Back door, rear quarter panel, rear and front doors done rain has stopped play.
Post #626160 Wed Aug 17 2022 5:52pm
skid1963
Looking good mate Thumbs Up 2015 L494 SDV6 3.0 HSE Loire Blue
Post #626161 Wed Aug 17 2022 7:00pm
Lrstaylor
Cheers Mark, iv got plenty todo before it's finished and at the standard I want. To think this is gonna be the wife's ulez replacment for her D3 when the zone expands.
Mite be on the move next year outside the M25 so who knows mite be able to keep all my landys
Post #626162 Wed Aug 17 2022 7:23pm
