Home > Maintenance & Modifications > Replacement Dynamic pipes question. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Aux cooler can be bypassed |
Sat May 07 2022 6:42am |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 210 |
I see does seem a bit excessive , now spent £12 quid dammit! Bit bulky but done , why would you need this ?
Sat May 07 2022 5:06pm |
Was standard on all pre facelift TDV8s
Sat May 07 2022 6:14pm |
Is that pipe affordable Mike, the link I made up is causing all sorts of problem in plastic fittings . Around inner shield and bumper, although I've fashioned it a bit . I like things as they should be, but maybe that link you used, is simple enough If I remove the matrix I could use the joints I have , they are just double house tails and a pipe. |
Sun May 08 2022 5:37pm |
Had to take the bumper off again for the umpteenth time! Inner arch was not right,. I researched the face-lift pipe and it was £200 , so redesigned my new link, and create more space. Tried to get s/h original pipe but it seems they are also rotten, and if they aren't they are sold with the radiator. |
Tue May 10 2022 7:14am |
Trying to move forward here, first of all I've found a garage with snap on to possibly bleed my unit .
Sun May 15 2022 8:23pm |
Tue May 31 2022 10:45pm |
Again , looks like no assistance here.
Sat Jun 25 2022 10:11pm |
Just to add 18hrs later with the the 20 amp fuse out F26 the rear suspension is unchaged but the front drivers has dropped 3.5 mm and nearside 4mm .Front driver was at 51mm and nearside 55 .That is taken for consistancy at the base of the centre cap.
Sun Jun 26 2022 11:28am |
Struggling to achieve full height, as in off road height? |
Sun Jun 26 2022 11:38am |
yes, especially drivers,. have it all stripped on full height at the moment and doing some leak detection on front valve block. |
Sun Jun 26 2022 1:17pm |
Ok found the pipe connection to the front drivers strut leaking.
Sun Jun 26 2022 1:38pm |
Sun Jun 26 2022 9:33pm |
