![]() | Home > Maintenance & Modifications > Replacement Dynamic pipes question. |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 213 ![]() ![]() ![]() |
I have been reading about Dynamic response pipes , front, and come to the conclusion that most folk , send to a garage to get replaced , Part NRQA500120
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4459 ![]() ![]() ![]() |
Separate the body. Support the body on axle stands and lower the chassis on jacks
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
Brit Plumber did a repair using high pressure fixings, not sure if you feel confident doing it yourself, and I doubt you would get a garage to do it.
If its a garage doing this how long does it take I am thinking hourly or days? Ill begin saving ! Looking now for a guide for body lift. After I get my MOT AT THE END OF THE MONTH. |
We turn them around same day, barring any unforseen issues. Allow for 8 hours |
I was hoping you would say that as I could make that to yourself in a day once I have resources . Or I get brave enough through the summer and DIY., if it lasts that long ! tHANKS |
No |
Would anyone know of a guide to a partial lift of the body on v8 diesal |
An hours subscription to Topix |
OK , thanks I have tried in the past to get a login to Topix and failed and still failing.
We have stock on the newer part number, LR015144
Thanks Mikey, Ill make enquiries locally, incidentally read your guide on here , was thinking that apart from removing wheel arch bit and bobs to reach body mounts to slacken doesn't seem too bad to raise 2 inches , would that be right. I also watched a video on that thread, shame I have a 4 post and not a 2 post, but hey ho I'm lucky to have that. |
Best tool to get at front dynamic feed pipe with torque tool , as my 10mmx75mm long 20 torx is broken I'm struggling, extremely tight and little room . |
It's OK, short tox bit and 10mm spanner, with a bit of Freeze and release!
