![]() | Home > Maintenance & Modifications > Replacement Dynamic pipes question. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4459 ![]() ![]() ![]() |
Front dampers can be taken off and binned. They are not required |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 213 ![]() ![]() ![]() |
Cheers , less expense! Any tips on bolt removal, other than weld a new nut and keep a fire extinguisher handy! |
Order accepted on that number, old number , all good though, thanks. |
Ah well I'll blog on, bolt head would no take a weld, must be made of dissimilar metal, tried every combination of society and eventually ground off the head. Unfortunately now I'll have to release the the rest of the two rears to extract the remaining stud! And yes the pipes are are nightmare to pull out, one to go. I think I've got the body high enough now. |
AH ! The suspension components, I left the suspension at full height, and had to remove the drop link and then the top arm, problem arose with the feed pipe to air spring, not protruding enough to catch the cooler nut and so wary of snPping the pure through it locating hole at the top of strut plate, any suggestions, perhaps just feed it through carefully as I remove the bag? |
Drop link comes off
ALL DONE THANK YOU .
Yeah tricky that pipe , got a bit squashed but still whole , I think.
From my sized body bolt that rounded, A wee bit of luck after two hours, getting an answer to extracting the remains!
Tried to edit earlier, apologies, meant to say seized bolt.
Got a question , the front four pipes came (as anyone who has done this) with clamps , keeping everything in place. I think they're fitted back to front comparing them to the old section lying out. It's just that they aren't happy lining up to the new rubber mounts I have screwed to the chassis leg.
Angled bit goes to the bottom and towards the chassis |
👍That solves it Mike thank you.
https://www.jgs4x4.co.uk/discovery-power-s...venol-ssf/
ORDERED !
