Home > Technical > Black smoke from one exhaust |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 220 |
Mine does exactly the same if I use kickdown , had it about 18 months now sailed through its MOT so I am presuming everything is ok, on 95,000 miles with no performance issues. |
Sat May 01 2021 12:07pm |
Harry1234 Member Since: 01 May 2021 Location: Doncaster Posts: 9 |
Thanks for reply, I can understand it happening on kick down but not on start up and only one exhaust, almost like it’s over fuelling on one Side of the engine |
Sat May 01 2021 3:19pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
It would be worth having it plugged in to a diagnostic and checking things like the EGRs, injector trims etc. 2012 SDV6 - it's missing a couple of cylinders
Sat May 01 2021 5:57pm |
I’ve had blanking plates fitted to both egrs and there are no fault codes at all, do the egrs need deleting via a remap? |
Sat May 01 2021 6:31pm |
Yes, the TDV8 needs a remap to delete the EGRs. 2012 SDV6 - it's missing a couple of cylinders
Sat May 01 2021 7:29pm |
Thanks for that I will get it booked in and hopefully that will cure it |
Sat May 01 2021 7:46pm |
Started a new thread |
Sun May 02 2021 12:08pm |
