Home > Technical > Black smoke from one exhaust
Harry1234
England 2010 Range Rover Sport TDV8 HSE Santorini Black
Hi, new to site and Range Rover ownership. So bought a 2010 3.6 tdv8 with reduced power, and black smoke from left exhaust as you look at it from back, anyway 2 new turbos later and back to full power. However on cold start up the left exhaust still smokes black but only until the engine revs die down after a minute or so, then completely clear until you rev it then black smoke again. When I’m driving no smoke at all unless I boot it then a puff of smoke then it’s ok, any ideas? Thanks Harry
Post #613140 Sat May 01 2021 12:43pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Mine does exactly the same if I use kickdown , had it about 18 months now sailed through its MOT so I am presuming everything is ok, on 95,000 miles with no performance issues.
Post #613141 Sat May 01 2021 1:07pm
Harry1234
Thanks for reply, I can understand it happening on kick down but not on start up and only one exhaust, almost like it’s over fuelling on one Side of the engine
Post #613147 Sat May 01 2021 4:19pm
It would be worth having it plugged in to a diagnostic and checking things like the EGRs, injector trims etc. 2012 SDV6 - it's missing a couple of cylinders
Post #613149 Sat May 01 2021 6:57pm
Harry1234
I’ve had blanking plates fitted to both egrs and there are no fault codes at all, do the egrs need deleting via a remap?
Post #613150 Sat May 01 2021 7:31pm
Yes, the TDV8 needs a remap to delete the EGRs. 2012 SDV6 - it's missing a couple of cylinders
Post #613152 Sat May 01 2021 8:29pm
Harry1234
Thanks for that I will get it booked in and hopefully that will cure it
Post #613153 Sat May 01 2021 8:46pm
Harry1234
Started a new thread
Post #613174 Sun May 02 2021 1:08pm
