![]() | Home > Technical > Black smoke from one exhaust |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 222 ![]() ![]() ![]() |
Mine does exactly the same if I use kickdown , had it about 18 months now sailed through its MOT so I am presuming everything is ok, on 95,000 miles with no performance issues. |
Harry1234 Member Since: 01 May 2021 Location: Doncaster Posts: 9 ![]() ![]() ![]() |
Thanks for reply, I can understand it happening on kick down but not on start up and only one exhaust, almost like it’s over fuelling on one Side of the engine |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9030 ![]() ![]() ![]() |
It would be worth having it plugged in to a diagnostic and checking things like the EGRs, injector trims etc. 2012 SDV6 - it's missing a couple of cylinders
I’ve had blanking plates fitted to both egrs and there are no fault codes at all, do the egrs need deleting via a remap? |
Yes, the TDV8 needs a remap to delete the EGRs. 2012 SDV6 - it's missing a couple of cylinders
Thanks for that I will get it booked in and hopefully that will cure it |
Started a new thread |
