Home > General > Dead after starter replacment |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Earth strap
Thu Jul 16 2020 12:17pm |
L111YDB Member Since: 14 Jul 2020 Location: West midlands Posts: 24 |
Where is the location.of that earth strap mate?
Thu Jul 16 2020 12:35pm |
RH engine mount - front of suspension turret on chassis - body
Thu Jul 16 2020 12:49pm |
I suppose that's a pain to get to aswell lol
Thu Jul 16 2020 12:54pm |
Little update.
Fri Jul 17 2020 9:30am |
Put the starter back on
Fri Jul 17 2020 9:51am |
I could do with turning the engine a few cycles by hand to eliminat engine seizure 100% really I think .
Fri Jul 17 2020 1:16pm |
Fairly common...
Fri Jul 17 2020 2:00pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
The starter won't run with it unbolted from the engine, as it isn't earthed.
Fri Jul 17 2020 4:00pm |
Right .
Fri Jul 17 2020 5:53pm |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 |
If you’ve not done so already I’d have a look on YouTube for how to test a starter motor, it’s quite easy to test them, you should be able to test both the stater motor and solenoid to see if you have a problem with either, with regard to the broken connector if you’ve got your old starter I’d test that also, depending with what’s wrong with that it might be possible to swop the solenoids over, I'm not sure from your description but I’m guessing the broken connector is on the solenoid. |
Fri Jul 17 2020 6:25pm |
Have you snapped the ring terminal with the captive nut? |
Fri Jul 17 2020 6:30pm |
No I've bost the bloody ring comnector on the lead . The lad who got his hands up there to get it back on said he needed to bend it so it was easier ......then snap.
Fri Jul 17 2020 6:44pm |
Fri Jul 17 2020 6:45pm |
