Home > General > Dead after starter replacment |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
Well you need to get brave. Stick it in park.
Wed Jul 15 2020 7:22pm |
L111YDB Member Since: 14 Jul 2020 Location: West midlands Posts: 24 |
I'm gonna pop outside in a bit just to check the starter turns if I bridge it with a screwdriver .
Wed Jul 15 2020 7:29pm |
Just tested the small wire and while cranking its live
Wed Jul 15 2020 8:27pm |
Does sound like battery |
Wed Jul 15 2020 8:52pm |
Took a battery off a pals v8 diesel and exactly the same.
Wed Jul 15 2020 10:21pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
Put the transmission in park or neutral and see if you can turn the engine by hand, if engine is seized shouldn't be able to turn it over, if it turns probably not seized at least.
Wed Jul 15 2020 10:26pm |
3.0 have similar probs to 2.7 |
Wed Jul 15 2020 10:52pm |
Before work this morning I turned the viscous fan bolt which made the crank turn to the point it hit compression . But it turned a few times ..
Thu Jul 16 2020 7:15am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
I read this and after the first few post I thought, engine seized and likely snapped crank. Try as Col said and turn the engine, if not, pull the starter and with it connected, press the start button and see if it works. I fear the worst but hope for the best. 2019 5.0 SC SVA (Current)
Thu Jul 16 2020 7:17am |
I get off work at so ill get on with it then .
Thu Jul 16 2020 8:08am |
As a long shot, what battery is it and where was it from? Have a look on the label (usually on the back) and see if there’s a calendar on it showing when it needs a recharge and if that recharge has been done. That recharge date is for when it’s stored on the shelf before purchase and not after it’s been fitted. There’s a chance it may be new but flat after 6 months on the shelf. And if it’s been done late, it could be too late with batteries such as Calcium (Often branded as silver) being beyond recovery. 2019 5.0 SC SVA (Current)
Thu Jul 16 2020 10:52am |
And please don’t tell me it’s a Halfords HSB019. 2019 5.0 SC SVA (Current)
I think he's tried a different battery from another vehicle and still the same.
Thu Jul 16 2020 10:59am |
Agh yes, just seen it.
Thu Jul 16 2020 11:12am |
