Home > In Car Electronics > New Android 9 Discovery/RRS Android Stereo System |
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 |
Thank you |
Tue Jun 16 2020 10:18am |
Luke, just a thought, if you want a factory look for the USB, you could get a late Disco 4 top glove box with the USB input, I’ve put one in mine and it just needed a locating tab trimming off the Disco 4 version for it to fit.
Wed Jun 17 2020 7:20am |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
Ok played around a little more today .
Wed Jun 17 2020 2:04pm |
After some more playing :
Sat Jun 20 2020 9:16pm |
Just to add, Apparently this is a software "Issue".
Mon Jun 29 2020 1:56pm |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Luke,
Mon Jun 29 2020 2:04pm |
I have had a few android units before , Never had them get hot enough to reboot loop :p
Tue Jun 30 2020 8:22am |
I've had a few different units some did overheat and shutdown, however, the Joying unit has performed well on that count, even with 40C heat here. It helps that the actual HU is nestled between the AC vents deep inside the dash.
Wed Jul 01 2020 9:41am |
OK installed their update today and the unit is sitting around 68-70c , This is with 2 map software's and their audio software playing. ( 20-30% load )
Thu Jul 02 2020 4:06pm |
OK Onboard microphone. Something is definitely not working correctly with it . They also don't provide an external Aux connector for an external Mic.
Mon Jul 06 2020 10:44am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Good news on the mic. Will you mount it in the interior light housing? Kev
Mon Jul 06 2020 12:09pm |
Unsure as of yet , Need to find out my options on the USB microphone really.
Mon Jul 06 2020 1:04pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
someone on youtube has fitted an android unit to a discovery. They said the internal mic was useless, and you should get one with an external mic input |
Mon Jul 06 2020 3:46pm |
To be fair my GF's bmw one is fine .
Mon Jul 06 2020 4:42pm |
