![]() | Home > In Car Electronics > New Android 9 Discovery/RRS Android Stereo System |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Ok after testing more in the car i noticed satnav sound stopped working (it was working on the bench randomly)
Ok after testing more .
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Great to hear you have got the system finally working as it should.
Hey ,
Cheers,
luckly downsizing the memory stick solved the issue , the 32gB one i was using has a problem i believe as it was disconnecting from the pc.
SUGO Member Since: 29 Dec 2020 Location: NOVARA Posts: 1 ![]() ![]() |
Hello! Same problem on my RRS "Zuolv" 10.25 unit ! What do you mean with "Remove pin 4 to pin 5 hole" ??? Another question: when I press voice command button on steering wheel it starts both Oem assistant and google assistant together, and one speak with the other aaaaargghhhhh, do you have the same problem? |
Hey , Sorry missed this response
For any one still interested in this unit. I have been using it quite a bit and it works fine now since the seller sorted out the problems.
