![]() | Home > General (L494) > Mystery unplugged connector near spare wheel |
It looks like it could have been for some kind of charger to keep the battery charged if stood,,chase the wires & see if they go to the battery. Andy.
cs10 Member Since: 07 Jun 2018 Location: suffolk Posts: 1 ![]() ![]() |
Had that on my 2017 model year, it was a connection for the soft close drivers door, leaves the factory unplugged and then connected before collection, |
BiffoBear Member Since: 23 Feb 2016 Location: Bucks Posts: 51 ![]() ![]() |
connected to what before collection? 2016 L494 SDV8 AB 2014 Nissan Leaf Tekna 1989 Toyota MR2 MK1b |
For the drivers soft close it says at the start |
I haven't got soft close so my question remains......connected to what? 2016 L494 SDV8 AB 2014 Nissan Leaf Tekna 1989 Toyota MR2 MK1b |
Nothing then just part of the loom |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
They don’t make a wiring loom dependant and what options your car has, that would be expensive
Thanks for all the replies.
Three-Six Charlie Member Since: 21 Mar 2019 Location: Wigan Posts: 63 ![]() ![]() |
It this was a Jaguar I'd say it was where the 'transit relay' was plugged in. (only had my RRS for 6 months, but owned Jags for 7 years beforehand- both my Jags had this.) Protects the battery from going flat in between manufacture and delivery. The Jag one is green and has connections to receive a two-pin male on it. Would be logical if Land Rover used the same system. 2013 L494 5.0 SC in Chile Red |
Aha....thanks Three-Six Charlie, I think you've hit the nail on the head ![]() I've not come across a 'transit relay' before but a bit of googling found a post on another LR forum which although referring to a different LR model, the photo shows an identical connector and a description that matches what you have described. https://www.landroverworld.org/threads/wiring-question.27703/ Explains why the connector and cable on mine are just 'floating about'. My OCD will require me to cable tie it out of the way ![]() 2014 Nissan Leaf Tekna 1989 Toyota MR2 MK1b |
