![]() | Home > Technical > Auto setting for suspension to low on igition off? |
Why would it though ? The car is specifically designed to allow drivers to lower it with the ignition off ?
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
Try it and see |
its all mechanical sympathy |
I do. On 98k miles and never an issue. As I say, I get the mechanical sympathy line but the handbook contradicts the argument. In fact the whole point of it having emergency ride height adjustment is to sort you out when you are grounded and stopped and the system is explicitly programmed to allow adjustment as stopped, as the handbook says, it goes out of its way to explicitly say you have 40 seconds to put it in access stopped with ignition off as long as you do not open driver door. If the car is designed to cope off road its hard to see how adjusting when stopped causes a problem and my own experience says not. |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Oh .. that's definitely not how I did the drive home from work last night ![]() ![]() |
You should buy a lottery ticket ![]() |
I don't need to. The rrs is essentially a discovery in a posh frock, designed to manage off road and fairly extreme terrains. The idea it would break through raising or lowering when stopped is infinitessimally small.
215m3 Member Since: 13 Sep 2018 Location: Cambridge Posts: 48 ![]() ![]() ![]() |
I use the lower option while on the move before parking up. It just becomes second nature. 2010 3.0 TDV6 RRS Overfinch GTS
