Home > Wheels & Tyres > 21” tyres creating traction problems? |
I’m sure the early sports weren’t designed for anything bigger than the 19’s as the steering rack wasn’t up-to them.it was around early 2007 that they change the rack for the 20’s to be fitted. Andy.
Fri May 10 2019 5:10pm |
DarrenSpain Member Since: 10 May 2019 Location: Hertfordshire Posts: 6 |
Cheers tyrefitter, well it is an early 2007, but that could possibly be the problem, steering is lovely and light though (too light in my opinion). I know the wheels aren’t meant to fit the L320, but theres no issues with rubbing anywhere, just the speedo being slightly out....and this sodding traction problem. |
Fri May 10 2019 5:20pm |
Don't that size potentially damage the rack if its not the later rack |
Fri May 10 2019 5:33pm |
Fri May 10 2019 5:36pm |
I shall go and check the rake out 👍🏻 Although i dont think that would be the traction issue would it? |
Fri May 10 2019 5:45pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 472 |
Check your VIN doesn't sit between these
Fri May 10 2019 6:12pm |
Just checked Vin im 7A99.... so guessing thats fine, although got a lot of oil over passenger side ball joint, so got a leak somewhere 😡 |
Fri May 10 2019 6:32pm |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 |
My 2005 RRS had 20" wheels on when bought it 2 years ago. No problems all. Interestingly the VIN is between the numbers Autobiography1969 quotes above. - Just checked... mine has damped steering gear as per the link above. Barrie.
Fri May 10 2019 6:45pm |
I did read somewhere on this site, a lot of people have larger wheels on the earlier models, just more BS from Land Rover covering there arses over ANOTHER problem!!! |
Fri May 10 2019 6:53pm |
Just quoting the VIN numbers from "geoffsnook" post as its an important detail in the recall/service bulletin..
Fri May 10 2019 6:55pm |
That is very true autobiography, always something with these motors |
Fri May 10 2019 7:06pm |
rangemogger Member Since: 09 Nov 2010 Location: Canary Islands , Spain Posts: 45 |
I will do an alignment , because rims offset seems to be different , independent suspension is very sensitive to changes TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool |
Mon May 20 2019 7:13pm |
green1652@hotmail.com Member Since: 19 May 2019 Location: Leicester Posts: 4 |
4 wheel alignment can make a massive difference to the feel and ride of your car just make sure they know what they are doing as places haven’t got a clue where to start with these cars |
Sun Jun 09 2019 3:46pm |
