Home > Wheels & Tyres > 21” tyres creating traction problems?
DarrenSpain
United Kingdom 2007 Range Rover Sport TDV6 HSE Santorini Black
Hi guys, took the stock 19 alloys off my 56 plate rrs and put on some new 275/45r21 alloys and tyres, still a nice smooth comfy ride, but when going around roundabouts (not fast) the traction control kicks in and i lose power, fine on straights and left/right turns.....anyone else had this problem, or know a solution? Ive heard it could be a dodgy ABS sensor, but why would it only play up on roundabouts? Any help would be appreciated 👍🏻
Post #580624 Fri May 10 2019 4:51pm
Tyrefitter
I’m sure the early sports weren’t designed for anything bigger than the 19’s as the steering rack wasn’t up-to them.it was around early 2007 that they change the rack for the 20’s to be fitted. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #580627 Fri May 10 2019 5:10pm
DarrenSpain
Cheers tyrefitter, well it is an early 2007, but that could possibly be the problem, steering is lovely and light though (too light in my opinion). I know the wheels aren’t meant to fit the L320, but theres no issues with rubbing anywhere, just the speedo being slightly out....and this sodding traction problem.
Post #580629 Fri May 10 2019 5:20pm
geoffsnook
Don't that size potentially damage the rack if its not the later rack Thumbs Up
Post #580630 Fri May 10 2019 5:33pm
geoffsnook
http://www.rrsport.co.uk/gallery/albums/us...20Rack.pdf Thumbs Up
Post #580631 Fri May 10 2019 5:36pm
DarrenSpain
I shall go and check the rake out 👍🏻 Although i dont think that would be the traction issue would it?
Post #580632 Fri May 10 2019 5:45pm
Autobiography1969
Check your VIN doesn't sit between these
5A900505 - 6A917472
If it does you will need to go back to 19's or drive very slowly around roundabouts.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #580633 Fri May 10 2019 6:12pm
DarrenSpain
Just checked Vin im 7A99.... so guessing thats fine, although got a lot of oil over passenger side ball joint, so got a leak somewhere 😡
Post #580634 Fri May 10 2019 6:32pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
My 2005 RRS had 20" wheels on when bought it 2 years ago. No problems all. Interestingly the VIN is between the numbers Autobiography1969 quotes above. - Just checked... mine has damped steering gear as per the link above. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #580636 Fri May 10 2019 6:45pm
DarrenSpain
I did read somewhere on this site, a lot of people have larger wheels on the earlier models, just more BS from Land Rover covering there arses over ANOTHER problem!!!
Post #580637 Fri May 10 2019 6:53pm
Autobiography1969
Just quoting the VIN numbers from "geoffsnook" post as its an important detail in the recall/service bulletin..
As with all these things there are always ones that have no issues at all and others that will suffer more,
A leak wont help at all though.. ===========================================
Post #580638 Fri May 10 2019 6:55pm
DarrenSpain
That is very true autobiography, always something with these motors
Post #580639 Fri May 10 2019 7:06pm
rangemogger
Spain 2008 Range Rover Sport TDV8 SE Rimini Red
I will do an alignment , because rims offset seems to be different , independent suspension is very sensitive to changes TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool
Post #581127 Mon May 20 2019 7:13pm
green1652@hotmail.com
4 wheel alignment can make a massive difference to the feel and ride of your car just make sure they know what they are doing as places haven’t got a clue where to start with these cars
Post #582109 Sun Jun 09 2019 3:46pm
