Home > Technical > 2.7 tdv6, no compression on cylinder 1: inlet valve stuck
do them all hand tight (5Nm) to pull the cam down.
Then go over them again to 10Nm
Post #574296 Sat Feb 02 2019 10:11am
Flexzor
Belgium 2009 Range Rover Sport TDV6 HSE Java Black
Thanks! Almost ready... The rest will be for next weekend.
Post #574358 Sat Feb 02 2019 8:20pm
So is this with the head left on?!
Post #574362 Sat Feb 02 2019 8:32pm
Flexzor
Yes!
I took the plunge and tried to repair it without pulling the head...
Bought a tool to compress the (broken) spring on the head.
Fitting the spring was no big deal. Removed inlet cam, piston at TDC: valve rested on piston and i was able to compress the spring again without any other tools.
Because the spring was still retracting the valve, but not completly, the valve was only some mm's not closing.
Fitted the new spring and tested with pressurizing the cylinder: now ok! Before air was escaping in the inlet manifold. Next weekend installing the injector rail, injectors etc again. (No time over week...)
Post #574520 Mon Feb 04 2019 5:20pm
Arh Thumbs Up
Got a link to the tool used ?
Post #574526 Mon Feb 04 2019 5:53pm
Flexzor
https://www.ebay.de/itm/SWV-8404086-Ventil...2749.l2649
Post #574606 Tue Feb 05 2019 12:42pm
