![]() | Home > Technical > 2.7 tdv6, no compression on cylinder 1: inlet valve stuck |
Flexzor Member Since: 29 Dec 2018 Location: Bruges Posts: 18 ![]() ![]() ![]() |
Hi!
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Humm. Could be. I guess you need to remove 1 cam and see |
Thanks for your prompt reply,
Removed valve cover, turns out to be a broken valve spring in the inlet side.
interesting
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 920 ![]() ![]() |
Fit a new valve or you may be revisiting it soon. If the piston is not parallel to the valve face, chances are the valve spindle may be bent. It may be just slightly bent but will quickly wear the valve guide or a hairline crack in valve seat. Not worth doing the job twice. You may not be so lucky the second time. |
Thanks for your replies guys.
To remove the exhaust you go in thru the wheel arch.
Thanks, clear instructions
Can say on.
The chain has 2 ? Dark red links to help with alignment on refitting.
Any idea about the torque settings for the camshaft caps? Don’t see to find them.. |
