Home > General (L494) > Oil dilution is our fault apparently!
Page 2 of 6 <123456>
DangerMouseUK
United Kingdom 2013 Range Rover Sport Supercharged Santorini Black
So is this any diesel JLR engine or specifically the SDV6/TDV6 variants?
If the DS has it then it must be the 2 litre as well but then aren't they two completely different engine designs?
If so, basically don't get another JLR diesel? Was going to get a Disco5 or Velar 3 litre diesel but very nervous now.
What do you guys think?
Post #571975 Sun Dec 30 2018 11:16am
Tyrefitter
Get a petrol Dangermouse.Its not just JLR having problems with diesels it’s most manufacturers,,since they started fitting dpf’s Their has been nothing but trouble.Before dpf’s & cats Diesel engines ran for ever If regularly serviced & they will have the same problems when they start fitting particulate filters to petrols. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #571977 Sun Dec 30 2018 12:37pm
DangerMouseUK
I would have gone for the three litre petrol in the Velar or Disco5 but they've pulled that model in both and didn't really want to get a 2 litre in either of those.
Not too keen on the 5ltr RRS at the moment for Central London so wanted to go for a Velar or Disco.
If the Velar SVR wasn't going to be full on (which it will be) I would have considered that as well but just don't know now.
Post #571979 Sun Dec 30 2018 1:00pm
Tyrefitter
JLR should have fitted the 3.0sc in the evoque as I think that would be a good seller. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #571982 Sun Dec 30 2018 1:38pm
harisson
Switzerland
If you google a bit, you will find the dilution issue with nearly every manufacturer.
My diesel BMW showed a longer service due then normally (about 34000km instead of 30000), but I changed the oil every 20000km. At 18000km I have seen a little drop in the board computer. I had also a dip stick and there the oil was slightly under the MAX value.
I drive my RRS with the same profile (work, holiday, weekend) and the service due is dropping faster then the driven kilometers.
I will keep an eye on it, but will go the way tp change every 20tkm for several reasons.
The SDV6 is a lovely engine. I had 270PS in my BMW and it was a fast sedan. I suppose that the RRS is as fast ad the BMW up to 160... Range Rover Sport HST D350
Post #572012 Sun Dec 30 2018 7:47pm
timhum
I don't believe there in enough room in the Evoque or Disco Sport to fit the V6 motor as they use their engines in a transverse position. In other models it mounted longitudally .
Tim Tim
RRS sold and replaced with a Skoda Kodiaq after appalling RR Dealer experience and LR inability to supply new cars in any sort of reasonable time frame..
Post #572036 Sun Dec 30 2018 10:47pm
DangerMouseUK
Its annoying they dropped the engine from the Velar even if they had the SVR coming as The P380 would have been my choice really.
They still sell it abroad which is even more annoying! They had the SI6 in the Disco5 as well so they had it there in slightly detuned version !
Post #572044 Sun Dec 30 2018 11:59pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Harisson,
My BMW X5 (now gone) was the same, 100% reliable but no DPF.
I think that BMW will have the same issues with their cars now they are also fitted with DPF's.
Regards
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #572133 Tue Jan 01 2019 1:58am
harisson
Switzerland
Barryp,
My BMW also had a DPF and I didn't know anything about oil dilution. After searching in internet I have seen that every manufacturer has oil dilution troubles with their Diesel cars equipped with DPFs.
As mentioned, I changed the oil every 20tkm instead of 30tkm. Range Rover Sport HST D350
Post #572184 Wed Jan 02 2019 8:31am
Black Bess
harisson
Interesting to hear of your experience. I think you have exactly the right strategy for your oil changes. I suspect that you will have no trouble doing what you are doing...
Adam..
Post #572206 Wed Jan 02 2019 12:07pm
mlines
Has anyone heard a definition of what a short journey might be? 2 miles, 10 miles, 100 miles?? 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #572235 Wed Jan 02 2019 5:07pm
harisson
Switzerland
@Black Bess
I seems to be so Smile let's see how it will be with the RRS. I have it since 11 months now..
@mlines
Good question. For me all mlre than 15km is no more short journey. Why? Because the cooling temperature is reaching the working area. I will buy a OBD dongle to check the cooling temperature in real, but as mentioned, for me it's important that the engine has reached the working temperature. I am trying to avoid journeys where I don't reach 90 degrees... Range Rover Sport HST D350
Post #572249 Wed Jan 02 2019 9:27pm
On Disco3 there was mention of needing to drive for 20 minutes at 40-70mph in order for the DPF to get hot enough to regenerate. Any shorter, presumably, and you're in to partial regens and lots of unburnt fuel in the sump...
"Sorry Officer, but Land Rover say I absolutely must do 70mph for 20 minutes in order to drive my RRS "correctly"!"
"Yes, Officer, I'm well aware that this is central London, but Land Rover were quite insistent..." Whistle Rolling with laughter Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #572253 Wed Jan 02 2019 11:35pm
harisson
Switzerland
@RRSTDV8
Yes, that's true but it is needed to regenerate the DPF if full, or nearly full...
On my old BMW you could recognize an ongoing regeneration (lower gear, deeper sound) and so, I drove few kms more until it was finished. It happened once in quarter year. All other regenerations were done during a journey.
I didn't recognize an ongoing regeneration with these "symptoms" on my RRS unfortunately Range Rover Sport HST D350
Post #572258 Thu Jan 03 2019 7:21am
Barryp
Agree, it would be great if we got an indication that one was in progress/required, at least we could then deal with the issue!
Very poor design by LR software experts!
Regards
Post #572260 Thu Jan 03 2019 8:43am
