Home > General (L494) > Oil dilution is our fault apparently! |
Get a petrol Dangermouse.Its not just JLR having problems with diesels it’s most manufacturers,,since they started fitting dpf’s Their has been nothing but trouble.Before dpf’s & cats Diesel engines ran for ever If regularly serviced & they will have the same problems when they start fitting particulate filters to petrols. Andy.
Sun Dec 30 2018 12:37pm |
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 |
I would have gone for the three litre petrol in the Velar or Disco5 but they've pulled that model in both and didn't really want to get a 2 litre in either of those.
Sun Dec 30 2018 1:00pm |
JLR should have fitted the 3.0sc in the evoque as I think that would be a good seller. Andy.
Sun Dec 30 2018 1:38pm |
harisson Member Since: 28 Jun 2018 Location: CH Posts: 184 |
If you google a bit, you will find the dilution issue with nearly every manufacturer.
Sun Dec 30 2018 7:47pm |
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 |
I don't believe there in enough room in the Evoque or Disco Sport to fit the V6 motor as they use their engines in a transverse position. In other models it mounted longitudally . Tim Tim RRS sold and replaced with a Skoda Kodiaq after appalling RR Dealer experience and LR inability to supply new cars in any sort of reasonable time frame.. |
Sun Dec 30 2018 10:47pm |
Its annoying they dropped the engine from the Velar even if they had the SVR coming as The P380 would have been my choice really.
Sun Dec 30 2018 11:59pm |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 |
Harisson,
Tue Jan 01 2019 1:58am |
Barryp,
Wed Jan 02 2019 8:31am |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
harisson
Wed Jan 02 2019 12:07pm |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 |
Has anyone heard a definition of what a short journey might be? 2 miles, 10 miles, 100 miles?? 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
Wed Jan 02 2019 5:07pm |
@Black Bess
Wed Jan 02 2019 9:27pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9008 |
On Disco3 there was mention of needing to drive for 20 minutes at 40-70mph in order for the DPF to get hot enough to regenerate. Any shorter, presumably, and you're in to partial regens and lots of unburnt fuel in the sump... "Sorry Officer, but Land Rover say I absolutely must do 70mph for 20 minutes in order to drive my RRS "correctly"!" "Yes, Officer, I'm well aware that this is central London, but Land Rover were quite insistent..." 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Jan 02 2019 11:35pm |
@RRSTDV8
Thu Jan 03 2019 7:21am |
Agree, it would be great if we got an indication that one was in progress/required, at least we could then deal with the issue!
Thu Jan 03 2019 8:43am |
