![]() | Home > Technical > Webasto FBH |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
You'll need that activating in the Car Configuration File- CCF. There are a few guys on here that can do that for you, and and sure they'll be along soon..
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 ![]() ![]() ![]() |
So I can just get a remote and job done instead of all that parafinalla of wiring in a unit for timer controls? Cheers Laurence. |
No.
Thank you |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
Does this mean that you've finally found one? ![]() 2013 Grey Black Edition SDV6 (lasted a while but gone now) 2005 Grey Supercharged Sport (gone but never forgotten) ![]() ![]() |
It certainly looks that way... |
I think timed climate was an option on most models but standard on the Black Edition. The FBH still works when needed even without the timed feature. 2016 Black SDV8 Autobiography
It works when the temp. Is low and the engine calls for it to aid engine warm up.
The plip is a small unit with on and off buttons.. 2011 MY D4 HSE
This is the plugin unit..
So I need this unit ^^ above^^, somebody activate the in Car Configuration File - CCF and a remote... |
That unit is just a WiFi switch, so I don't think that will work on your car. The Webasto needs a signal, not just a live feed to start.
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Buster check out the link from bodsy
Gone 4.2 supercharged RRS Gone 90 Gone s2000 |
I have made up a ctek adaptor, it's really handy |
