Home > Technical > Hunter Wheel Alignment
Page 2 of 3 <123>
Tyrefitter
I cannot help you with that question as I’ve never had anything to do with hunter equipment
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #567703 Fri Oct 26 2018 7:19pm
amgmaj
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Ok thanks @Tyrefitter Thumbs Up
Post #567704 Fri Oct 26 2018 7:20pm
amgmaj
Just checked I don't think I have dynamic response on my range rover sport 3.0 2010
Post #567705 Fri Oct 26 2018 7:38pm
Tyrefitter
No it doesn’t look like you have,,yours is one of the models I haven’t had,I went straight from a 08 to a 12 plate.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #567706 Fri Oct 26 2018 7:42pm
amgmaj
Thanks once again mate Thumbs Up
Post #567707 Fri Oct 26 2018 7:44pm
Brit Plumber
That one should be ok if you don’t have dynamic.
I’m assuming the software is for all countries. If so, I think the USA and Australia got the 5.0 NA engine. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #567708 Fri Oct 26 2018 7:52pm
DrRob
Did they lock it in Tight Tolerance Mode with a plug in diagnostic? If not, then forget it. All air suspension vehicles need putting into TTM for 4 wheel alignment.
And don’t be fobbed off with the old “we leave a door open mate” Censored Visitor from fullfatrr.com
Post #567709 Fri Oct 26 2018 7:54pm
amgmaj
Yes software all countries I was next to the screen when he was doing the alignment.
Which RRS 2.7, 3.6, 5.0 setting should I go with when I take it back tomorrow if he can't a RRS 3.0 setting?
Post #567710 Fri Oct 26 2018 8:10pm
amgmaj
I put it in TTM myself outside the garage with IID Gap tool Thumbs Up
Post #567711 Fri Oct 26 2018 8:11pm
Yours may have dynamic response. Dynamic response is the name of the hydraulically activated ant roll bars. Dynamic mode is part of the Terrain Response system. Different things, I'm afraid, and often confused even on here.
To check whether you have Dynamic Response, open the bonnet. If you have it, there will be two yellow topped reservoirs, one next to the washer fluid filler and radiator header tank (this one is the power steering reservoir), and another one on its own on the other side next to the air filter box.
Two yellow reservoirs = dynamic response, one yellow reservoir = no dynamic response. 2012 SDV6 - it's missing a couple of cylinders
Post #567712 Fri Oct 26 2018 9:01pm
DrRob
Wot he said ^^ Thumbs Up Visitor from fullfatrr.com
Post #567722 Sat Oct 27 2018 7:46am
Slim444
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I had my castor/camber/toe done on a Hunter machine last week, as it seemed to be pulling to the left slightly, and steering wheel off centre too. This was after I had the lower front suspension arms changed and geometry had been done.
The guy who did mine said you should ideally have ¾ tank of fuel in too when the set up is done, although very few people do!
Going back in to my indy on Wednesday as now have another 'clunk' when steering from left to right when moving. Will probably get the transmission fluid change done too, the bills are really starting to rack up Sad You can't see the eyes of the demon until him come callin'
Post #567726 Sat Oct 27 2018 11:29am
amgmaj
All sorted now steering wheel straight and no pulling towards the left Smile
Alignment re'done with RRS 2.7 setting instead of FFRR setting on the Hunter machine, the driver side front wheel needed a little teak, all good now.
Thank you for your help everyone much appreciated Thumbs Up
Post #567768 Sat Oct 27 2018 6:20pm
amgmaj
Could you please tell me if my RRS has Dynamic response by looking at the pictures of my engine bay?
Post #568067 Thu Nov 01 2018 6:18pm
Brit Plumber
It’s the big yellow cap in the centre bottom of the second photo. 2019 5.0 SC SVA (Current)
Post #568069 Thu Nov 01 2018 6:28pm
Page 2 of 3 <123>
