![]() | Home > Wheels & Tyres > 27540R20 or 275/45R20. ? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
So long as all tyres are the same, DSC etc won't care. A change in sidewall height will alter the speedo but not by enough to worry about. 2012 SDV6 - it's missing a couple of cylinders
275 45 much better ride |
clarkey1 Member Since: 14 Feb 2018 Location: Bucks Posts: 25 ![]() ![]() |
Thanks for the reply,
Not without mods full fat range rover use that size i think |
ok, thanks for the replies, so quick to.
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Don’t forget to inform your insurer if moving away from standard fitment. |
fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180 ![]() ![]() ![]() |
Agree with Geoff, much better ride. |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Ok, so I run 275/55R20s but have raised the suspension by 10 or 15mm to compensate.
275/40R22 = 30.7" diameter
285/50R20 = 31.2" diameter *Now Added for Completeness* ![]() ![]() Hope that helps. I'd personally now go for a 275/45 or 275/50 R20 tyre for road use also, the 22s look nice but the ride is trashed... Cheers Guy 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" Last edited by Guyzer73 on Tue Mar 13 2018 8:28am. Edited 1 time in total |
Mate !
Guy,
Winston Member Since: 03 Nov 2016 Location: Nairobi Posts: 6 ![]() ![]() ![]() |
Hi Guy, Is there a noticeable difference in the ride? Cheers |
Winston, between which tyre sizes?
Thanks Guy good to know, I have 20" Wheels with the 40 profile in Nairobi, there is too many potholes here and the ride is not great so will look to go up to a 45 and maybe an AT tyre depending on whats available locally
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Nothing wrong with the ride on 22`s |
