Home > Wheels & Tyres > 27540R20 or 275/45R20. ?
Page 1 of 3 123>
clarkey1
I was wondering about over sizing the tyres;-
1. To make a slight improvement on ride quality
2. bigger tyre in wheel arch looks better.
So does running the oversized tyre cause any problems with any electronic systems like the stability control programme (because of the change in wheel speed) ?
is a 275/50 R20 out of the question ? (I think it would look ridiculous anyway)
thanks
Post #548592 Wed Feb 14 2018 2:19pm
So long as all tyres are the same, DSC etc won't care. A change in sidewall height will alter the speedo but not by enough to worry about. 2012 SDV6 - it's missing a couple of cylinders
Post #548599 Wed Feb 14 2018 4:04pm
geoffsnook
275 45 much better ride Thumbs Up
Post #548601 Wed Feb 14 2018 4:16pm
clarkey1
Thanks for the reply,
So I could go to 275/50R20 and there would be no problems other than a speedo error.
that is a tyre diameter of 30.8 inches,
Im fairly sure people run with 32 inch off road tyres don't they ?
Thanks
Post #548602 Wed Feb 14 2018 4:18pm
geoffsnook
Not without mods full fat range rover use that size i think Thumbs Up
Post #548603 Wed Feb 14 2018 4:22pm
clarkey1
ok, thanks for the replies, so quick to.
cheers Very Happy
Post #548605 Wed Feb 14 2018 4:28pm
GodivaNige
Don’t forget to inform your insurer if moving away from standard fitment.
Post #548606 Wed Feb 14 2018 4:40pm
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Agree with Geoff, much better ride.
Post #548639 Thu Feb 15 2018 7:35am
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Ok, so I run 275/55R20s but have raised the suspension by 10 or 15mm to compensate.
However, in the past I have had 285/50R20s and these ran no problem except for a slight rub on full lock, but I suspect this is due to the bumper not being straight rather than anything else...
Oh and I ran 275/40R22s...
That equates to the following diameters (approximately):
275/55R20 = 31.9" diameter
275/40R22 = 30.7" diameter
285/50R20 = 31.2" diameter
*Now Added for Completeness*
Hope that helps. I'd personally now go for a 275/45 or 275/50 R20 tyre for road use also, the 22s look nice but the ride is trashed...
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #548641 Thu Feb 15 2018 7:56am
clarkey1
Mate !
Thanks for taking the time to put this on here.
Thats a great help.
Many Thanks
Bow down Bow down
Post #548726 Thu Feb 15 2018 5:54pm
clarkey1
Guy,
Finally got round to changing the tyre. Well Happy Laughing
Thank you for the help posting your pics.
here it is...
Post #551046 Sun Mar 11 2018 2:48pm
Winston
Kenya 2010 Range Rover Sport 3.0 TDV6 Autobiography Zermatt Silver
Hi Guy, Is there a noticeable difference in the ride? Cheers
Post #551160 Tue Mar 13 2018 5:57am
Guyzer73
Winston, between which tyre sizes?
Basically, the 22"s were the most sporty with great grip and handling - what you'd expect with road tyres. But the ride was too harsh.
Both the 285/50s and 275/55s provide a very plush ride quality but obviously lack in the handling department due to the taller sidewalls. But then again the Sport isn't meant to be a Jaguar XKR, even if the shared the same engine...
The 275/45s that many go for is probably the best compromise with regards handling and ride quality. Pus you may even find some semi off road AT tyres in the size. I can't comment on this first hand though as I have never installed tyres of this dimension.
Hope that helps a little.
Post #551177 Tue Mar 13 2018 7:32am
Winston
Thanks Guy good to know, I have 20" Wheels with the 40 profile in Nairobi, there is too many potholes here and the ride is not great so will look to go up to a 45 and maybe an AT tyre depending on whats available locally
Best regards
Post #551193 Tue Mar 13 2018 10:23am
Cymruambyth
Wales
Nothing wrong with the ride on 22`s Rolling Eyes Steve.
Post #551196 Tue Mar 13 2018 11:16am
Page 1 of 3 123>
