Home > Technical > Intake Manifold Repair
Sharpy1980
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Having just read the highlighted posts above I take back what I said and a repair looks like a pointless exercise Bow down Clickadeeclick
Post #544244 Thu Dec 28 2017 3:43pm
N60613
Bosnia Herzegovina
that can be fixed if you familiar with working epoxy and composites( aramid aka kevlar and carbon fiber fabric) small quantities can be had at beter hobby shops. clean the surface well with brake cleaner and roughen up the surface with 120 grit sand paper than use JB Weld or similar epoxy and rubit in the crack. prepare laminating epoxy, wet fabric and apply 2 layers of kevlar 120g and finis with carbon fiber 120. fabric needs to overlap crack by 3/4' to 1'. cover with food wrap and apply pressure till epoxy sets.
in the picture i mark places to grind down.
Post #544245 Thu Dec 28 2017 3:43pm
Rockyward
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Bonatti Grey
Anyone tried to repair the crack using superglue and baking soda ?
Like this ...
Post #621805 Sat Feb 12 2022 3:48pm
Disco_Mikey
Problem is, the manifolds are a weak design
"Repair" it, and the crack only moves to a weaker part, until this happens...
Glue is fine as a temp repair, but sooner or later, you'll be replacing the manifold
Post #621806 Sat Feb 12 2022 5:02pm
Rockyward
Mine is only a small crack I think I'm going to try super glue and baking soda, I have 3 weeks to wait before the Dealer can look at it.
I presume I have nothing to lose.
Driving it under 2000 revs for 3 weeks is tricky as I live in a hilly area and if the restricted performance kicks in, it drives like I have a puncture and end up with a long line of traffic behind me when I go up hills.
Good job I can override the auto box's gear changes with the Command Shift paddles.
Thanks.
Post #621807 Sat Feb 12 2022 5:32pm
Stand Easy
Both mine cracked, warranty specifically said inlet manifolds weren't covered, however, given that my engine had been refurbed by the same warranty firm they agreed to pay half the costs. Had a quote of £750 for genuine parts all fitted, clearly a cheap quote Whistle , got job done and went to collect the vehicle. "I've underquoted you by £800" said the mechanic Big Cry , "my fault though so I won't ask for any more" he said. Bow down Result was the warranty paid half of the £750 and I got a £1550 job done for £375. Result Thumbs Up
Post #621818 Sat Feb 12 2022 8:53pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi i had a interesting call with LR Customer service or non service to be honest.So there is a LR bulletin LTB00768v2 an official document that states under cause:Material Thickness and fillet radius of the valve cover not to specification.I asked as they state it’s not to specification so by that statement not fit for purpose they would be replacing any defective units covered by the vin numbers they listed free of charge?Guess what they said NO! as there had not been a recall.So they can release cars with parts that fail their own specifications and put them on vehicles with no recourse.
The fact that there quality control failed and by that they supplied vehicles with a defective part they still expect the vehicle owner to pick up the bill for their quality control failure and management failure on this.
Surely their must be a legal firm who would take this on with the UK equivalent of a USA CLASS Action Law Suit.
Thought please as this can’t be correct . Thumbs Up
Post #621826 Sun Feb 13 2022 8:25am
Apples24
United Kingdom 2006 Range Rover Sport TDV6 HSE Lux Java Black
How did you get on with the glue repair?
Post #629097 Wed Dec 14 2022 5:56pm
erickwan
Malaysia
Drill a hole whose diameter is at least twice the width of the crack at both ends. Then use the superglue-baking soda method to seal up the crack.
Post #629177 Fri Dec 16 2022 4:52pm
