![]() | Home > Technical > Intake Manifold Repair |
Sharpy1980 Member Since: 24 Sep 2016 Location: Kent Posts: 98 ![]() ![]() ![]() |
It’s worth a try just make sure you use a 2 part epoxy resin like araldite or gorilla glue and clean the crack and surrounding area with brake cleaner and the give it a good rough up, you could even try and weld the crack back together first with a soldering iron and cover with resin just be careful not to make any holes as you don’t want any lumps of dried glue inside the intake,
DSJ Member Since: 25 Sep 2015 Location: Birmingham Posts: 41 ![]() ![]() ![]() |
will the manifold have to be completely removed?
That would depend on where the crack is but if you have to remove the manifold I would sooner replace it rather than repair if it were mine,
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4460 ![]() ![]() ![]() |
Warranty on a 7yr old car? Can only ask...
how do i avoid any lumps of dried glue inside the intake?
just spoke to dealer, they will firstly carry out diagnostic at £152 per hour even though fault is visually obvious.
Epoxy is quite thick so won’t run through the crack unless there’s holes, as for warranty direct I would have thought it will be covered as it can hardly be regarded as wear & tear but then you never know, I’m sure if you get a written quote from an Indy you can present it to WD to get authorisation before the work begins, on the other hand if your handy with the spanners and the part isn’t to expensive then it may be less hassle to get it sorted right and then you have piece of mind it won’t go again Clickadeeclick |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 320 ![]() ![]() ![]() |
Mine had been glued back together when I bought the car, a week in there was a load bang and it blew a hole big enough to get my finger in. Given the pita removing injectors etc to get to the manifold, I would just replace it. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5067 ![]() ![]() ![]() |
LTB00768v2 a Pdf copy is in my gallery, not sure how to add it to post.
thanks, read these two thoroughly last night.
Jampot1979 Member Since: 23 Jun 2017 Location: Bedfordshire Posts: 145 ![]() ![]() ![]() |
I had the driver's side inlet manifold replaced on my TDV8 last month due to a hairline crack. Cost me approx £750 all in by my local specialist. It's abit of a pain to get at and remove but they did it all in approx 4 hours. I would rather replace than glue. I would worry about it failing. |
N60613 Member Since: 24 Jun 2016 Location: capljina Posts: 32 ![]() ![]() |
DSJ, can you post picture of the crack? |
here you go - from another thread. |
