Home > Technical > QUESTION REGARDING BATTERY REPLACEMENT
craigdunne
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Alaska White
hi,
Im new to this and also new to having a RRS. I have recently purchased a RRS 2010 TDV8 and have had a few gremlins. I took it back to the garage i purchased it from and the errors were coiming up with low voltage warning. They therefore said that they put in a brand new battery. My question is, when i picked it up all my preset radio stations were still there, my memory seats were still set and my sat nav still had my destinations in. would this suggest that they never replaced the battery or does it save all this info somehow?
Your help is greatly appreciated.
Post #542362 Fri Dec 01 2017 6:16pm
It retains all that.
The clock and bass treble settings are the giveaway.
Post #542365 Fri Dec 01 2017 6:24pm
craigdunne
Thanks very much, they did change the battery then after all.
Post #542371 Fri Dec 01 2017 7:29pm
Only things you loose with changing battery on a facelift is clock on dash will revert to 2009 but that might be if you change the CCF files if I remember correctly, the analogue clock time, one touch window operation and I think sunroof closing but all simple to reset.
Post #542380 Fri Dec 01 2017 7:58pm
