Home > Technical > QUESTION REGARDING BATTERY REPLACEMENT |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
It retains all that.
Fri Dec 01 2017 6:24pm |
craigdunne Member Since: 01 Dec 2017 Location: MIDDLESBOROUGH Posts: 11 |
Thanks very much, they did change the battery then after all. |
Fri Dec 01 2017 7:29pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
Only things you loose with changing battery on a facelift is clock on dash will revert to 2009 but that might be if you change the CCF files if I remember correctly, the analogue clock time, one touch window operation and I think sunroof closing but all simple to reset.
Fri Dec 01 2017 7:58pm |
