![]() | Home > Technical > QUESTION REGARDING BATTERY REPLACEMENT |
It retains all that.
craigdunne Member Since: 01 Dec 2017 Location: MIDDLESBOROUGH Posts: 11 ![]() ![]() ![]() |
Thanks very much, they did change the battery then after all. |
Only things you loose with changing battery on a facelift is clock on dash will revert to 2009 but that might be if you change the CCF files if I remember correctly, the analogue clock time, one touch window operation and I think sunroof closing but all simple to reset.
