![]() | Home > General > Engine top end strip down |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
Cheers Andy. OK next to go on will be the heat shields, 3 of them I think there are, then I will put back on the EGR valve. RRS 2.7 HSE Stornoway Grey
OK, I didn't take the advice given to me when taking off the left hand side heat shield guards around the exhaust manifold area. So I'm stuck trying to sus out what one goes where. I have 5 guards to fit. I have the exhaust manifold one fitted OK which leaves four to fit.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
yeah I regretted not taking pics too.
Yes thanks Andy. I did however manage to get another one of them damn heat shields on, well I made it fit in |
Yeah I make the mistake thinking the heat shield went ontop of the EGR rather than the manifold.
Managed to get the heatshields on and then tried to get the EGR on but cannot get the bottom bolt in. Think I may have to take shields off again and access the bottom EGR bolt through the wheel arch? But even with shields off not sure if I can access that bolt as main silver turbo pipe may be in the way!!! other option is take EGR back out and put the bottom bolt in first then put EGR back in... not sure though. RRS 2.7 HSE Stornoway Grey
I think we are talking cross purposes.
I think so Andy. I fitted the the exhaust manifold heat shield first of all then fitted the ones that cover the wheel arch area. I will take them off again (marking them this time |
Got most of the LH side back together.
When you say breather. Do you mean the black plastic part ? Or metal pipes?
I should have taken a picture of it but yeah I mean the plastic part. OK cheers Andy I will have another go tomorrow. Got to admit though was good to get the LH side mostly done today. |
As I said there are 2 things below that bracket which need unbolting.
I thought I had every bolt out from behind the bracket that holds pipes etc; on but the head is still hanging on for dear life. I do feel one very small 8mm bolt way down the back, no idea how I will get that one off right enough. But yeah the RH side has been really straight forward until I hit this nightmare snag, oh well hopefully get it off some other time. |
