![]() | Home > General > Engine top end strip down |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
The manual indicates the positions. |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
I've scanned through the workshop manual and do see plenty of detail regarding the camshaft fitting, torque etc; but not the level of detail I need about bearing cap numbers, letters, location sequence. If you have the the manual and can let me know the page number that would be grand. RRS 2.7 HSE Stornoway Grey
I do see in the LR workshop manual reference to letters A to I and R to Z
I have had a look at the relevant section of the topix manual - the sequence seems pretty straight forward and I don't see that diagram you have posted.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4459 ![]() ![]() ![]() |
One bank is numbered, one bank is lettered.
From the Citroen workshop manual ![]() |
Thanks garrycol, the picture I attached in earlier post is an extract from the C6 Citroen manual. Can you send me a link to the topix manual. RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Good stuff DM that's the kind of thing I was hoping to hear. RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Its on Topix so you will need to buy a subscription and download it (or at least the sections you need) - it is the LR genuine information. https://topix.landrover.jlrext.com/topix/ 07MY RRS TDV6 Arctic Frost Aspen Interior |
does seam that the Citroen manual is better.
Cheers garrycol RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Thanks Andy, yes glad I found this online as was bit worried when the bearing caps not in sequence when heads arrived. Anyways hopefully get a bit further now the weekend is nearly here. ![]() P38 4.6 HSE V8 |
And that in itself would worry me enough not to use it |
Got most of this list checked off at the weekend. Feels like I'm getting somewhere... eventually. Regarding the EGR valve for the LH side, does this actually have to go back onto the car? I can't just blank the exhaust manifold and pipework off? RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
