Home > General > Engine top end strip down |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
storm update...
Sat Aug 12 2017 2:13pm |
I'm now at the rear cam pulley. Thought I read somewhere that the casing had to be cut/destroyed to gain access to the cam pulley bolt. How do I at least attempt this one? RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Sat Aug 12 2017 3:52pm |
Got the rocker cover off and removed cam shafts to gain access to the 8 head bolts. Next job to tackle will be fuel pump side. What's to be done at this stage? RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Sat Aug 12 2017 3:58pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
good work.
Sat Aug 12 2017 4:45pm |
Cheers... I think the chain tensioner is OK, I lifted it out along with the small spring.
Sat Aug 12 2017 6:07pm |
That's correct. |
Sat Aug 12 2017 7:03pm |
would recommend you get this on order from china.
Sat Aug 12 2017 7:30pm |
if/when it comes to needing heads, I would recommend these guys.
Sat Aug 12 2017 7:35pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Curious Andy, how did you torque up the rear cam pulley bolt? |
Sat Aug 12 2017 8:19pm |
I removed the cam with the wheels still on, with the belt cover hanging around it
Sat Aug 12 2017 8:36pm |
I'm starting to undo the high pressure fuel pump tensioner bolt, total pig to get to. What's the score with taking the belt off at this stage, do i just continue to take the tensioner bolt fully out. How does the belt slacken.
Sun Aug 13 2017 4:48pm |
2.7 belt isn't timed, so take it right off
Sun Aug 13 2017 5:38pm |
80Nm then 90 degrees Cam seals need fitted in place once the cam caps have been torqued Then the cam pulleys need fitted and tightened... |
Sun Aug 13 2017 5:40pm |
Good stuff thanks DM. RRS 2.7 HSE Stornoway Grey
Sun Aug 13 2017 6:01pm |
