Home > Technical > coding help required
Page 2 of 3 <123>
Johnski
Best of luck, I'm not sure I would want to rewire and sort several issues out that can occur, Airbags, and curtain airbag wiring etc. Wink John
Post #518981 Sat Feb 25 2017 9:31pm
donny dog
Where are you getting all the parts from?
Post #518982 Sat Feb 25 2017 9:31pm
dddrrift
United Kingdom 2007 Range Rover Sport TDV8 HSE Zambezi Silver
It looks worse than it really was, def wouldnt take on a completely destroyed one, this was scorch and isolated flame damage really. The wiring looms were pretty much undamaged. The only ones affected were the main dash harness which i replaced completely, all plug and play connectors... and the roof harness again has a plug connector to remove and reinstall a new one.
Im hoping this minimises faults but im sure there will be something that pops up! Very Happy
Decided when i bought it that if i was going to do it i might aswell do it right so thats why i gutted everything, there were bits that could have been saved but id rather just change it all to be sure.
Parts have been sourced all over the place really, kent4x4 and MMJ provided a lot along with another seller on ebay.
The only parts iv yet to buy is a headcloth and a nav screen, everything else is there Very Happy
Post #518998 Sun Feb 26 2017 12:14am
donny dog
Well your a better man than me! I look forward to seeing the finished job, but I've every confidence it will be good.
Post #519006 Sun Feb 26 2017 8:28am
I'd be getting the thing running first before spending money on a lovely interior.
Post #519026 Sun Feb 26 2017 10:43am
dddrrift
well i cant really do that @andy k as i need an instrument cluster which is coming as a package deal with the dash. remember i know this car, it belonged to a friend, so i know the mechanicals are all good. if i had of bought it knowing nothing about it then as you say, getting it running would have been priority.
Post #519034 Sun Feb 26 2017 11:57am
Black Bess
Looking good!
Keep the pics coming.
Post #519148 Mon Feb 27 2017 1:28pm
dddrrift
will do my best, once I get going I forget to take pictures Rolling with laughter
expecting my new dashboard today so hopefully have some updates tonight Very Happy
Post #519311 Tue Feb 28 2017 12:09pm
dddrrift
bit of an update...
managed to get her fired up over the weekend! yay! Spent around 6 hours with a multi meter tracing the medium speed Canbus as I was unable to communicate with the BCM module. This was stopping me doing any coding or starting the car!
Got my new clocks coded, recoded the keys, dash mostly fitted and shes running. No faults other than transmission fault, but im pretty sure its the shifter as its original and no doubt got soaked.
Post #520761 Mon Mar 13 2017 1:23pm
SRE
Spain
Well done Bow down
It's always worth looking on the sister forum's (Disco 3/4) for tech help and parts. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #520764 Mon Mar 13 2017 1:36pm
dddrrift
yes I see the disco 3 seems to share a lot of parts etc
have you the link to the other site?
Post #520766 Mon Mar 13 2017 1:45pm
SRE
Spain
Look at the bottom of the RR Sport homepage
But just to help out try http://www.disco3.co.uk Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #520767 Mon Mar 13 2017 1:54pm
SRE
Spain
RR Sport and Disco are basically the same, just that the Disco has a van like skin. Plus the Disco boys are more into tweaking and DIY repairs, whereas we are more into polishing. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #520768 Mon Mar 13 2017 1:56pm
dddrrift
thanks for that!
yes I gathered that! Rolling with laughter range rover technical help is quite hard to get online, most people seem to just run to the dealer at the first sign of trouble Smile
Post #520772 Mon Mar 13 2017 2:24pm
geoffsnook
I just moved from a disco to a range and yes i did prefer fiddling/adding parts to my disco which quite a few camr from a range rover sport but now all i do is seem to clean my range rover sport but it is quieter on here Thumbs Up
Post #520791 Mon Mar 13 2017 5:51pm
Page 2 of 3 <123>
