Home > Technical > coding help required |
Best of luck, I'm not sure I would want to rewire and sort several issues out that can occur, Airbags, and curtain airbag wiring etc. John
Sat Feb 25 2017 9:31pm |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
Where are you getting all the parts from? |
dddrrift Member Since: 22 Feb 2017 Location: Belfast Posts: 26 |
It looks worse than it really was, def wouldnt take on a completely destroyed one, this was scorch and isolated flame damage really. The wiring looms were pretty much undamaged. The only ones affected were the main dash harness which i replaced completely, all plug and play connectors... and the roof harness again has a plug connector to remove and reinstall a new one.
Sun Feb 26 2017 12:14am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
I'd be getting the thing running first before spending money on a lovely interior. |
Sun Feb 26 2017 10:43am |
well i cant really do that @andy k as i need an instrument cluster which is coming as a package deal with the dash. remember i know this car, it belonged to a friend, so i know the mechanicals are all good. if i had of bought it knowing nothing about it then as you say, getting it running would have been priority. |
Sun Feb 26 2017 11:57am |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Looking good!
Mon Feb 27 2017 1:28pm |
will do my best, once I get going I forget to take pictures
Tue Feb 28 2017 12:09pm |
bit of an update...
Mon Mar 13 2017 1:23pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Well done
Mon Mar 13 2017 1:36pm |
yes I see the disco 3 seems to share a lot of parts etc
Mon Mar 13 2017 1:45pm |
Look at the bottom of the RR Sport homepage
Mon Mar 13 2017 1:54pm |
RR Sport and Disco are basically the same, just that the Disco has a van like skin. Plus the Disco boys are more into tweaking and DIY repairs, whereas we are more into polishing. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon Mar 13 2017 1:56pm |
thanks for that!
Mon Mar 13 2017 2:24pm |
I just moved from a disco to a range and yes i did prefer fiddling/adding parts to my disco which quite a few camr from a range rover sport but now all i do is seem to clean my range rover sport but it is quieter on here |
Mon Mar 13 2017 5:51pm |
