![]() | Home > Technical > 2.7 with ACE alternator removal |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
I found the opposite. A firm pressure, just causes it to slip on the belt, or tools to bend.
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 ![]() ![]() ![]() |
Lol, I tried being nice and applying pressure but didn't have any joy, I was reading on disco3 that a few people had fan nut trouble and give it 1 good hit to try and shock the nut, it worked for some and not for others, so I went out to car and said to it loosen or I'll trade you in for a disco but that didn't shock it, |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
They are huge.lol i was surprised how heavy and long they were when they arrived, as long as my forearm. I'm guessing one with the funny end goes over the bolt heads on one of the pulleys and the other is for the fan itself. |
The things are bloody difficult to undo after 100K miles of motoring |
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 ![]() ![]() ![]() |
Using something solid steel like a blunt chisel , try hitting the flats on the fan. This will make it less comfy .. |
Is that what happened to your idler..lol |
Yes, you don't really expect it to be made out of chocolate ... |
Lol, please don't, there's nothing more valuable than first hand experiences, good or bad. That's how we learn |
That's alternator sorted. 👌 But yes I must confess I chickened out and called a mobile mechanic they went to my home wile I was at work and completed the job, don't like admitting defeat tho. 😡 But on the plus side got the car for the weekend. Happy days. 😋 |
......mines still in bits until daylight |
Hi mate, what were your symptoms ? , well your range,s symptoms? |
It started with battery light randomly coming on and going out, then finally car cut out wile driving, called aa and they put a battery on car for me to get home approx 10 miles and by time I got home the special program was inactive, parking sensors were all out of whack and my airbag light was on, all seems back to normal now (airbag light had to be reset as didn't just go out once repaired) |
Ok thanks ours did similar but we didn't have a battery to put on so needed recovery |
