Home > Technical > 2.7 with ACE alternator removal
Page 2 of 3 <123>
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
ive not looked at the tools but I suggest a firm pressure will undo it as apposed to a shock from a mallett Smile
Post #517955 Thu Feb 16 2017 12:55pm
I found the opposite. A firm pressure, just causes it to slip on the belt, or tools to bend.
Where as a wack undid the thing.
To assist another way is to hold the one half tight, is to remove 2 of the 3 small fan bolts.
You either use the holes to put 2 prongs in to secure.
or use a metal bar with 2 holes in it and re-secure with the bolts.
[URL=]
[/URL]
Post #517956 Thu Feb 16 2017 12:57pm
Gilly1
Lol, I tried being nice and applying pressure but didn't have any joy, I was reading on disco3 that a few people had fan nut trouble and give it 1 good hit to try and shock the nut, it worked for some and not for others, so I went out to car and said to it loosen or I'll trade you in for a disco but that didn't shock it, Laughing that was when I give it a love tap with mallet but still no joy. Will give it another bash over weekend (not litrely) Mr. Green
Post #517958 Thu Feb 16 2017 1:14pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Gilly1 wrote:
I have been looking at the tools on the link provided but can't understand how they will undo the fan as they look quite hard to get any leverage on them, if holding pulley with pry bar and large adjustable on fan nut being shocked with a large rubber mallet didn't work. (But that's why I'm probably not a mechanic) keep us posted how you get on with the recommended tools and how tight your fan was. 👍
They are huge.lol i was surprised how heavy and long they were when they arrived, as long as my forearm. I'm guessing one with the funny end goes over the bolt heads on one of the pulleys and the other is for the fan itself.
Post #517963 Thu Feb 16 2017 2:33pm
The things are bloody difficult to undo after 100K miles of motoring
Post #517981 Thu Feb 16 2017 5:54pm
m3nutter
Using something solid steel like a blunt chisel , try hitting the flats on the fan. This will make it less comfy .. Laughing
When I said pressure I didn't mean gentle , I meant " give it some welly " Laughing
Post #517985 Thu Feb 16 2017 7:39pm
Danv8
Is that what happened to your idler..lol
Post #517988 Thu Feb 16 2017 8:14pm
m3nutter
Yes, you don't really expect it to be made out of chocolate ... Laughing .
Was only trying to help...I will keep my mouth shut from now on.
Post #517993 Thu Feb 16 2017 8:53pm
Danv8
Lol, please don't, there's nothing more valuable than first hand experiences, good or bad. That's how we learn Thumbs Up
Post #518000 Thu Feb 16 2017 9:46pm
m3nutter
.....and believe me I have had both good and bad Razz
Post #518015 Fri Feb 17 2017 5:41am
Gilly1
That's alternator sorted. 👌 But yes I must confess I chickened out and called a mobile mechanic they went to my home wile I was at work and completed the job, don't like admitting defeat tho. 😡 But on the plus side got the car for the weekend. Happy days. 😋
Post #518076 Fri Feb 17 2017 5:03pm
m3nutter
......mines still in bits until daylight Confused
Post #518081 Fri Feb 17 2017 7:48pm
m3nutter
Hi mate, what were your symptoms ? , well your range,s symptoms?
Post #518084 Fri Feb 17 2017 7:56pm
Gilly1
It started with battery light randomly coming on and going out, then finally car cut out wile driving, called aa and they put a battery on car for me to get home approx 10 miles and by time I got home the special program was inactive, parking sensors were all out of whack and my airbag light was on, all seems back to normal now (airbag light had to be reset as didn't just go out once repaired)
Post #518103 Sat Feb 18 2017 5:42am
m3nutter
Ok thanks ours did similar but we didn't have a battery to put on so needed recovery Big Cry
Post #518106 Sat Feb 18 2017 7:20am
Page 2 of 3 <123>
