Home > General > Range rover sport 2.7 tdv6 battery
Pxcars
United Kingdom 2006 Range Rover Sport TDV6 HSE Santorini Black
Hi everyone just a quick one would you recommend a lucas battery think it's 017 for my truck? Or varta one?
Post #514482 Sat Jan 14 2017 8:27pm
Considering Lucas ones are around £65 on eBay they have to be worth ago.
I think the originals are varta.
Post #514483 Sat Jan 14 2017 8:38pm
Pxcars
Yeh had spied them on the bay! Think I will try one.
Post #514489 Sat Jan 14 2017 9:15pm
Disco_Mikey
Exide Premium is the battery of choice for the D3/RRS Thumbs Up
Post #514491 Sat Jan 14 2017 9:48pm
DrRob
Listen to Mikey Thumbs Up Visitor from fullfatrr.com
Post #514495 Sat Jan 14 2017 10:29pm
adameverett
Just bought a battery last week after starting issues when freezing. Went through same question. Cheap Lucas/ umbongo, or brand. Read up on here about all the funny faults that start to play up because of a bad battery so decided against it. Went for a Bosch S5 019 in the end £102 (steal) from euro car parts. Check their bay shop as its cheaper than their counter. A car that throws errors because of a simple break switch or cheap break bulbs, 70 quid vs 102 no contest for me.
Post #514518 Sun Jan 15 2017 9:35am
Lost for Words
Can't vouch for the seller, but since the Tayna price has shot up, it looks like this is the place to go for the Exide: http://www.ebay.co.uk/itm/Exide-100Ah-900C...3641.l6368
Lucas - Prince of Darkness! Visiting from DISCO3.CO.UK
Post #514523 Sun Jan 15 2017 9:55am
Pxcars
Thanks all for your input will do few checks Monday on alternator etc. Was my own fault left it idling to defrost heated f an r screen on lights blower. Oh and heated seat! Thought that might be nice when I jumped in!! 🙈 what a mistake came back out headlights flashing hazards on every light on dash!!!
Post #514528 Sun Jan 15 2017 10:14am
There seams to be lots of evidence of non genuine alternators causing problems, but you never hear of this about batteries.
Post #514530 Sun Jan 15 2017 10:35am
Tim in Scotland
BTW pointless putting the seat heater on if you aren't sitting on it as they have a sensor in them that won't switch them on until somebody is sat on them............. at least this is the case with L494RRS, both Evoques and the 2010 FFRR that I have run since my 2007MY TDv8 RRS. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #514532 Sun Jan 15 2017 10:56am
Pxcars
Yeh could be as the alternator was replaced before I bought it. Battery doesn't look that old but when under cover would look new. I suspect battery as I don't use It as much as I should and sometimes slow winding over.
Post #514534 Sun Jan 15 2017 11:06am
I don't think this is the case with the early models the OP has.
I know this has been discussed before at length.
I am kind to mine and only put the front screen on to start with.
I only tend to use the low heat setting on the seat heater, even when its freezing.
It's quick enough
OP If you aren't using the car much, invest in a CTEK charger.
Post #514535 Sun Jan 15 2017 11:07am
Pxcars
Few tests done looks like cooked alternator! Crying or Very sad what make you think I should put on? Thanks David
Post #514684 Mon Jan 16 2017 2:49pm
Lost for Words
OE Denso. Thumbs Up Visiting from DISCO3.CO.UK
Post #514710 Mon Jan 16 2017 6:09pm
