Home > General > Range rover sport 2.7 tdv6 battery |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4986 |
Considering Lucas ones are around £65 on eBay they have to be worth ago.
Sat Jan 14 2017 8:38pm |
Pxcars Member Since: 17 Dec 2016 Location: Trefeglwys Posts: 13 |
Yeh had spied them on the bay! Think I will try one. |
Sat Jan 14 2017 9:15pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Exide Premium is the battery of choice for the D3/RRS |
Sat Jan 14 2017 9:48pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Listen to Mikey Visitor from fullfatrr.com
Sat Jan 14 2017 10:29pm |
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 |
Just bought a battery last week after starting issues when freezing. Went through same question. Cheap Lucas/ umbongo, or brand. Read up on here about all the funny faults that start to play up because of a bad battery so decided against it. Went for a Bosch S5 019 in the end £102 (steal) from euro car parts. Check their bay shop as its cheaper than their counter. A car that throws errors because of a simple break switch or cheap break bulbs, 70 quid vs 102 no contest for me. |
Sun Jan 15 2017 9:35am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Can't vouch for the seller, but since the Tayna price has shot up, it looks like this is the place to go for the Exide: http://www.ebay.co.uk/itm/Exide-100Ah-900C...3641.l6368
Sun Jan 15 2017 9:55am |
Thanks all for your input will do few checks Monday on alternator etc. Was my own fault left it idling to defrost heated f an r screen on lights blower. Oh and heated seat! Thought that might be nice when I jumped in!! 🙈 what a mistake came back out headlights flashing hazards on every light on dash!!! |
Sun Jan 15 2017 10:14am |
There seams to be lots of evidence of non genuine alternators causing problems, but you never hear of this about batteries. |
Sun Jan 15 2017 10:35am |
BTW pointless putting the seat heater on if you aren't sitting on it as they have a sensor in them that won't switch them on until somebody is sat on them............. at least this is the case with L494RRS, both Evoques and the 2010 FFRR that I have run since my 2007MY TDv8 RRS. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Jan 15 2017 10:56am |
Yeh could be as the alternator was replaced before I bought it. Battery doesn't look that old but when under cover would look new. I suspect battery as I don't use It as much as I should and sometimes slow winding over. |
Sun Jan 15 2017 11:06am |
I don't think this is the case with the early models the OP has. I know this has been discussed before at length. I am kind to mine and only put the front screen on to start with. I only tend to use the low heat setting on the seat heater, even when its freezing. It's quick enough OP If you aren't using the car much, invest in a CTEK charger. |
Sun Jan 15 2017 11:07am |
Few tests done looks like cooked alternator! what make you think I should put on? Thanks David |
Mon Jan 16 2017 2:49pm |
OE Denso. Visiting from DISCO3.CO.UK
Mon Jan 16 2017 6:09pm |
