Home > Technical > idling problems
Dave_telford
United Kingdom 2005 Range Rover Sport Supercharged Zambezi Silver
idling problems
having problems with me tick over she will not idle starts up every time but then cuts straight out
any pointers or help would be much appreciated (4.2 supercharged )
Post #506545 Tue Sep 27 2016 5:54pm
nosmokenopoke
United Kingdom 2009 Range Rover Sport TDV6 Autobiography Zambezi Silver
Hi Dave. A scan and the codes will help mate otherwise is a needle in a haystack.
Could be anything airmass to fueling ect
Jon
Post #508272 Fri Oct 21 2016 8:02pm
Dave_telford
ok thanks jon
Post #508561 Tue Oct 25 2016 12:52pm
Spanner
Mine randomly does exactly the same thing, and doesn't store any sort of fault code. I cleaned the MAF sensor but it hasn't made any difference. I've seen somewhere it may be a software update that's required.
Post #508661 Wed Oct 26 2016 2:39pm
Socast
I had the same issue, if you give the engine a little throttle when you start it won't stall/stop.
If so there's a software update for it. Ask your local indy to put the latest ecu software on and you're hot to trot (Might be worth updating the software on the gearbox at the same time, not related to your issue but worth while doing) Thumbs Up
Post #509065 Tue Nov 01 2016 10:00am
Spanner
Is that something that can be done with an IID tool, or is it something only a garage / dealer can do?
Post #509070 Tue Nov 01 2016 11:13am
Socast
Depends on your tool but the one from GAP will.
Post #509135 Wed Nov 02 2016 9:39am
Spanner
Yeh, it's the GAP Bluetooth one Thumbs Up
Post #509136 Wed Nov 02 2016 10:11am
