Home > Technical > idling problems |
Dave_telford Member Since: 15 Feb 2016 Location: Shropshire Posts: 22 |
having problems with me tick over she will not idle starts up every time but then cuts straight out
Tue Sep 27 2016 4:54pm |
ok thanks jon |
Tue Oct 25 2016 11:52am |
Spanner Member Since: 22 Aug 2016 Location: Staffordshire Posts: 35 |
Mine randomly does exactly the same thing, and doesn't store any sort of fault code. I cleaned the MAF sensor but it hasn't made any difference. I've seen somewhere it may be a software update that's required. |
Wed Oct 26 2016 1:39pm |
I had the same issue, if you give the engine a little throttle when you start it won't stall/stop.
Tue Nov 01 2016 9:00am |
Is that something that can be done with an IID tool, or is it something only a garage / dealer can do? |
Tue Nov 01 2016 10:13am |
Depends on your tool but the one from GAP will. |
Wed Nov 02 2016 8:39am |
Yeh, it's the GAP Bluetooth one |
Wed Nov 02 2016 9:11am |
