![]() | Home > Technical > idling problems |
Dave_telford Member Since: 15 Feb 2016 Location: Shropshire Posts: 22 ![]() ![]() ![]() |
having problems with me tick over she will not idle starts up every time but then cuts straight out
ok thanks jon |
Spanner Member Since: 22 Aug 2016 Location: Staffordshire Posts: 35 ![]() ![]() ![]() |
Mine randomly does exactly the same thing, and doesn't store any sort of fault code. I cleaned the MAF sensor but it hasn't made any difference. I've seen somewhere it may be a software update that's required. |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
I had the same issue, if you give the engine a little throttle when you start it won't stall/stop.
Is that something that can be done with an IID tool, or is it something only a garage / dealer can do? |
Depends on your tool but the one from GAP will. |
Yeh, it's the GAP Bluetooth one |
