Home > In Car Electronics > HDC Fault, Transmission Fault, Special Programs Not Availab
Page 2 of 3 <123>
Paddi
Many owners, including this one, regularly connect a smart charger to the main battery without disconnecting and have no problems. Even if you do disconnect the battery there are no problems with resetting except perhaps you'll have to pair your 'phone to use Bluetooth.
Get the garage to investigate and then argue with the warranty company whether the fault is wear and tear or not.
Guava in Guildford are supposed to be a good place but I don't know if that's anywhere near you. Good luck! 2008 MY Java Black TDV8 HSE
Post #507640 Wed Oct 12 2016 12:26pm
nas16309
United Kingdom 2009 Range Rover Sport TDV8 HSE Buckingham Blue
Cheers mate
I will use the charger tonight and ring Gauva as they are about 45 mins from mine
Will keep you posted
Post #507643 Wed Oct 12 2016 12:42pm
Paddi
BTW Sorry - couldn't find a pic of the reservoir and my RRS isn't here at the moment but if you look in the owner's handbook under 'maintenance' there are a couple of drawings showing you with a description of how to check it. 2008 MY Java Black TDV8 HSE
Post #507645 Wed Oct 12 2016 1:08pm
nas16309
Thanks again
I spoke to dealer and am booked in tom.i told him to check the things which we discussed and the guy is like the forums lead up the garden path ! It's rubbish as actually I learn here a lot and make more sense.
Will defo look in manual mate and some people say that once Range Rover crosses 100k miles it starts giving problems.. Any of your thoughts as mine is 107000 now.
Paddi I am into property maintenance and I owe you one . If you have any maintenance issues with your property anytime give me a shout please I will be very happy to attend. I will send my details over if there is way to send a private message
Thanks a lot
Post #507652 Wed Oct 12 2016 1:52pm
Paddi
Oh yes - forgot to say do not mention forums to garages - it never goes down well Laughing
Hope they can fix your issues though. There's no magic number for the mileage at which these cars give trouble as it is about how they are driven and how thorough the maintenance has been (and fortune plays a part).
No need to reciprocate with any favours (but thanks anyway). Post up the results of the investigation as it could help someone else - that's how forums work best.
Thumbs Up 2008 MY Java Black TDV8 HSE
Post #507659 Wed Oct 12 2016 3:30pm
nas16309
Hi Paddi
Update - car has been in garage since Thursday with the dealer and put a new brake switch but the fault codes still remain. He advsised they checked all mechanical side and could not locate and its diagnosed by their best technician ! Now they need car till Monday as they want to check electrics and carry further diagnosis to identify problem.
My instinct says there is something minor which they are not looking at it or missing out. Fingers crossed let's see what happens. It's just a pain ! Any further ideas by Paddi and other boarders are most welcome.
Thanks in advance
Post #507846 Sat Oct 15 2016 7:20am
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi Nas, iv'e been following this post with interest and i need to ask one question to you. Are both of your brake lights working, have you got a blown bulb or have you changed any of them lately ? Just to add have you had your alternator checked as mine was dying and i had these symptoms before it went altogether. These beasts are very fussy when it comes to battery and alternator issues and will play you up. I did purchase a Lidl battery charger last week and it's spot on mate... Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #507853 Sat Oct 15 2016 9:57am
nas16309
Hi Gornal
Thanks mate.
Around 3 weeks ago the AA guy changed the brake light bulb when I first reported the fault to them who had also changed the brake light switch.
This dealer as Paddi said earlier does not seem to like when I give suggestions. It's the lack of attention to details is causing this and something is being ignored by them despite having the best tools. To give an idea I have incurred so far £360 of diagnostic costs.
Battery / alternator seems to be issue as I will know what they say on Monday. If I am born again I want to be a mechanic - wishful thinking !! I have Lidl charger and did not use but gave the car to them to sort out thinking that costly repairs would be covered by warranty.
Do please check my posts for updates please and I am very determined to fix
Kind regards
Post #507855 Sat Oct 15 2016 10:24am
nas16309
Hello all
Update recieved from dealer they can't figure out !!! They are now sending info to Land Rover UK to ask for assitance
Can't believe this could get so complicated.
Car has been 5 days with them!!
Paddi, Gornal and other mates pls throw some ideas here. It seems they have done all electrical tests as well and cannot locate the issue. So frustrating and only hope is that guy who assists me in dealer as he is a genuinely helpful
Post #508051 Tue Oct 18 2016 4:07pm
Paddi
I can fully understand how frustrating it must be. The truth is that faults like this can be very difficult to trace if they are related to problems with the numerous control modules and/or the wiring that connects them. Probably your best bet is to wait and see what JLR's technical department comes up with. Hopefully they will send a senior tech to deal with it.
Perhaps you could try and make contact with Land Rover customer services and get the problem expedited and as a goodwill gesture have the bill reduced if and when the dealer comes up with a solution. 2008 MY Java Black TDV8 HSE
Post #508058 Tue Oct 18 2016 5:24pm
Lonerangerv8
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
Hi all. Just to clarify about the charger from lidl one of which I have.
Can the battery be charged without disconnecting if using this charger.
Post #508066 Tue Oct 18 2016 7:41pm
nas16309
Hi Paddi
Thanks for the guidance and encouragement.
Let's see what they say and will keep posted
Kind regards
Nas
Post #508078 Wed Oct 19 2016 6:14am
nas16309
Hi Paddi and others ,
At last !! Please see the attached image taken from the invoice. It was an issue with the brake light switch which I can't understand head or tail of it. What baffles me is how come the brake light switch can trigger so many faults. The dealer was also getting frustrated as they tried many attempts in adjusting and finally they adjusted to 6mm which was tested ok. How could this not be picked up with so many tools. The guy who works there has been very helpful and did not charge me
much.
The car is fine so far and is back with me after 7 days ! Lesson learned not to apply brake sudden and at good speed although I did when someone tried to cut me.
Paddi you are a top man and so all others who contributed and guessed the problem with brake light switch. Thanks to Martin the owner of this forum for giving a chance to interact and seek some comfort.
Kind regards
Nas
Post #508266 Fri Oct 21 2016 6:24pm
Paddi
Thumbs Up good to hear the problem is solved.
I'm a bit mystified as to how the brake pedal brake light switch is adjusted since there is no facility for adjustment. Perhaps the slightly flimsy bracket it is mounted on became bent slightly by a ham fisted installation of the new switch and the dealer tech has bent it back to shape?
Can't see any way heavy braking could affect things. 2008 MY Java Black TDV8 HSE
Post #508347 Sat Oct 22 2016 3:36pm
nas16309
Hi Paddi
I see what you say and agree. Problem seems to be some where relating to brake switch as I have attached this latest photo which I took as it appears randomly only at the time of starting the car and then disapppears. So frustrating mate ! Don't know what to do now as they said to bring it back but I don't want to and just drive till the fault gets exposed by itself.
It's my belief some setting relating to brake is disturbed. Any more guesses? This is doing my head in as again the suspension will start getting lowered and so on. paddi and other folks could someone see the photo please and advise possible areas.
Thanks
Post #508349 Sat Oct 22 2016 5:30pm
Page 2 of 3 <123>
