Home > In Car Electronics > HDC Fault, Transmission Fault, Special Programs Not Availab
Page 1 of 3 123>
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Hi All,
Most of us may have come across this fault over the years however I cannot appear to get rid of it!!
HDC Fault, Transmission Fault, Special Programs Not Available, suspension lowered.
I changed the battery last week hoping this will disappear but unfortunately it hasn't.
Any suggestions would be much appreciated.
RRS 2005 4.4V8
H
Post #498634 Tue Jun 14 2016 4:45pm
Johnski
Have you got any fault codes? That is always a good place to start if fault not known. John
Post #498642 Tue Jun 14 2016 5:50pm
nas16309
United Kingdom 2009 Range Rover Sport TDV8 HSE Buckingham Blue
Hello friends, I drive a 2009 sport.. very grateful to all members who advised on changing brake switch light..which i did avoiding expensive repairs.
after one day the got the fault saying HDC unavailable transmission fault !!
If I take to the dealer they will definitely come up with a huge bill.
please can some one give some ideas as to how i take it from here or any areas to explore
i had instant brakes as one guy changed the lane last minute at good speed and that's the time I had the fault shown..
Any thoughts most welcome
Post #506911 Sun Oct 02 2016 4:33pm
Paul_selby
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hi . I know you said you've changed the brake light switch but I would change again . Mine went a week after getting my s/c and as I was used to driving a manual I was maybe a bit too hard on the brakes, as I got the faults after braking quite hard. Have you had it plugged into diagnostics ?
Post #506912 Sun Oct 02 2016 5:04pm
nas16309
Thanks mate for reply
Am taking to dealer on Tuesday and will take it from there
My past experiences with local mechanics has been horrible.
I think I shall wait for the report what they say and take it from there.
I just need to understand that's the difficult bit. Previously I spent £2k on transmission fault and is less then 16 months when the work was done by Land Rover dealer.
Again anything you have in mind let me know pls.
Kind regards
Nas
Post #506913 Sun Oct 02 2016 5:35pm
nas16309
Hello there
Been to the Land Rover dealer
They adjusted the brake switch light again and cleared all the faults
They told me to inform them if a fault arises
Just 2 mins away from their garage the fault came back !
It started with vehicle lean when cornering then after sometime HDC transmission fault was shown again with fault codes as shown in photo
So it's a bit of a wasted cost of diagnosis today and result is same
Have booked in again
Please let me know folks of any areas to look
Kind regards
Post #507026 Tue Oct 04 2016 4:03pm
Paddi
You need to upload any photos to your gallery and then paste the link in to your post.
Basics first - have you tried fully charging the battery. The Sport doesn't like low battery charge. Needs a proper overnight charge with a decent smart charger. Just running the car for a couple of hours isn't good enough.
'Vehicle lean' though sounds like a problem with the active roll control. Have you checked the reservoir under the bonnet to see if the fluid level is low? Any fluid drips from front or rear? 2008 MY Java Black TDV8 HSE
Post #507028 Tue Oct 04 2016 4:31pm
nas16309
Hello Paddi
Nice one much appreciate for reply
I am going to check battery and see the fluid
Any suggestions how I can charge battery for this sport and which smart charger I should buy?
Is the fluid called active roll which is under bonnet
Sorry mate am quite poor in terms of technical knowledge
Thanks
Post #507031 Tue Oct 04 2016 4:50pm
Paddi
Now it is not often you'll see the words 'Range Rover' and 'Lidl' used in the same post but it seems the aforementioned discount supermarket is currently selling a smart charger for £13.99 and it is a good one according to a helpful previous post. If you can't make it to Lidl before they sell out then go for the CTEK brand and you need a 5 amp one (mx5.0 model) but they are a bit stronger money at about £50.
An older type of unregulated charger will do the job but has to be used with a bit more care. The smart chargers are just 'clip on and forget' until the green light comes on.
The reservoir you are looking for is under the bonnet near the front of the engine bay and towards the offside. If it needs topping up then make sure you only use the correct fluid that you can buy at the Land Rover dealership.
For servicing it is always best to use an independent Land Rover specialist that's recommended by another owner. Put up a post saying which part of London you are in and someone will probably recommend a place.
Thumbs Up 2008 MY Java Black TDV8 HSE
Post #507037 Tue Oct 04 2016 5:58pm
R4zb3rry
Might be worth looking at the steering wheel angle sensor as I had same messages on mine including the lean when cornering.
Post #507043 Tue Oct 04 2016 8:34pm
nas16309
Hi Paddi
No words mate for your role.
I will buy the charger tomorrow and treat this as learning curve for me. hate to see those lights in dashboard.
Will check the fluid level and I should be able to find with your input.
Am based in Sutton Surrey but will have to find out some good specialist who can diagnose the fault correctly. I believe there is something somewhere which is triggering faults. Also I had taken my car to a garage to sort tracking and perhaps they unsettled some sensor. The steering is not striaght as it should.
I shall keep you posted of developments.
Once again thanks for your input
Post #507044 Tue Oct 04 2016 8:34pm
nas16309
Hi
I got the charger from Lidl ! Lucky to find one. The faults disappear and come back again and I noticed each time I use brake it appears. It is definitely something minor which the dealer could not pick up up. Do you think after charging battery overnight and checking fluid active I also get the brake lught switch replaced again.
Just to add I also have a warranty covering for 1 more year.
Am looking around for good mechanic in my area Sutton Surrey and if any member is aware please let me know
many thanks
Post #507166 Thu Oct 06 2016 8:24am
nas16309
Hello Paddi
Hope all good
It's now very clear to me that problem appears to be brake switch light.
Although it's been replaced recently but as one of the borders suggests I may need to do again. I noticed the fault appears only immediately when I use brakes and this random and not all the time.
It's best I get the dealer to do it this time. Will keep you posted
Kind regards
Post #507595 Tue Oct 11 2016 5:57pm
Paddi
I'm worried you may be jumping to conclusions in blaming the brake pedal switch considering you already changed it.
Did you fully charge the battery yet?
Did you check the fluid level in the ARC system; was it low?
Any fluid leaks front or rear?
Any fault codes recorded?
Lastly - as you have a warranty why not just leave it to a good independent to sort out and claim on the policy? 2008 MY Java Black TDV8 HSE
Post #507630 Wed Oct 12 2016 10:33am
nas16309
Thanks Paddi
I will be honest with you when I bought the Lidl charger my neighbour warned that the battery need to be disconnected as this would upset the setting. Therefore I did not charge but will buy from halford ctek version 5 today and will charge it without disconnecting the battery.
I could not locate the active roll oil under bonnet and if there is a picture you could send will assist me please. There are no leaks below
The faults come and do and engine wise it's smooth and nothing seems wrong.
I will need to have a word with the warranty guys as they don't do for wear and tear as they had previously advised to dealer.
Sorry mate I am just very poor when it comes to technicals
Post #507637 Wed Oct 12 2016 11:10am
Page 1 of 3 123>
