Home > General > Would A Gearbox Reset Help Or Cure ... |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi, on puling away i get a shunting feeling towards the rear of the car, and every time i slow right down and accelerate the same again. If i pull over and turn off, Restart after 10 seconds it has gone and back to silky smooth Please any advice on this would really help Just to add 67000 miles but it is an 07, could it need a gearbox flush ?? 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Fri Sep 09 2016 3:11pm |
Hi again, Have just checked the router ,make sure i'm connected Any ideas folks 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Fri Sep 09 2016 4:31pm |
Hiya,
Fri Sep 09 2016 5:05pm |
Hi Bodsy and thanks for the reply. i did think the gearbox oil was coming to the end of its life and i did wonder if it needed changing. I will be in touch soon to sort out my EGR's and also a gearbox reset, got it back now after having someone chop the bumper off and it looks good, thanks again. 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Fri Sep 09 2016 9:10pm |
Bodsys Brake Bible
Fri Sep 09 2016 9:33pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Also check the rear prop mounting, very guilty for collapsing
Sat Sep 10 2016 6:35am |
Hi Mikey, thanks for the reply, its fine over 20mph but when below it feels like the prop (rear) has 1 bolt left to undo 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sat Sep 10 2016 9:24am |
As did mine |
Sat Sep 10 2016 1:35pm |
Thanks again for the advice 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sat Sep 10 2016 1:50pm |
Ok folks, done it again today. Pulled away and thought the prop shaft was loose, no oil in the rear diff, clunking symptom up to 15 MPH. I stopped, turned off for 10 seconds and restarted, smooth as silk thereafter. No sticking EPB or rear pads and its not a misfire, Do i need a gearbox reset ??? Every time i restart it has gone altogether 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Fri Sep 16 2016 9:12pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Transfer box clutch calibraton? Visiting from DISCO3.CO.UK
Sat Sep 17 2016 10:28am |
Hi LFW, and thanks for the reply, in simple terms to a Locksmith is this easy to do...and how I did think it was mechanical at first but turning on and off never repaired prop shafts, bearings or the diff in my book,that's why i was wondering about a gearbox reset or hard reset ... 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sat Sep 17 2016 1:16pm |
You can try this...
...but it seems it doesn't work on all vehicles, in which case you need a diagnostic tool - just a 5 minute routine. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Sat Sep 17 2016 5:00pm |
Hi LFW, thanks again bud i'll try it later on today 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Sep 18 2016 10:59am |
Ok folks, had the prop checked today and all fine. It drove to the garage like a bag of K******s, turned off for 5 mins, started up and perfect again..... Please, Please, Please any ideas would be welcome (does it sound like the Torque Convertor) 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Wed Sep 21 2016 10:45am |
