Home > General > Would A Gearbox Reset Help Or Cure ...
Disco_Mikey
Had one in yesterday, the CV joint n the rear prop sounded very dry, and rattled like a Censored when rotated
Failing that, it could also be a worn suspension bush, but you would expect it to be present all the time
Leads us back to transfer box calibration...
Post #506007 Wed Sep 21 2016 12:07pm
Gornal Hills
Hi Mikey, thanks very much for the reply again, is it worth pluging in the box of tricks to calibrate the gearbox or try the other method as mentioned by LFW, willing to try anything, cheers 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #506017 Wed Sep 21 2016 3:45pm
